03-18-2021, 06:24 AM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
How much is too much for the street?
I've been so focused on making as much power as I can, that I blew right past my suspension and traction capabilities and now the car is useless on the street. Which is where I mainly drive it.
I've tried adjusting the BMR drag package (strange DA shocks/anti roll bar) every which way possible, have a 325/50/15 ET R tire and still cant hook in 3rd. Last week, I had to swallow my pride and install a larger pulley to lower the boost. The tune is fat and I've only seen 13psi so far (working my way up in RPM), but second gear is still not happening. How much power can you consistently put down on asphalt? and what is your suspension setup?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
03-18-2021, 08:14 AM | #2 |
Drives: 2013 1ss Join Date: Jul 2012
I only have 610 rwhp and have traction issues on the street. The temperature has to be above 70 and tire pressure lower than i want to run on the street to get good traction.
That said there is no "too much power" , the right pedal controls that. Its alwsys better to have reserve than not enough. |
03-18-2021, 08:25 AM | #3 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I can nail it if I'm running around 40mph; otherwise, I have to roll into the throttle. I run 325/30/20 Michelin Sport Cup 2s.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
03-18-2021, 08:49 AM | #4 |
This is about 50% throttle in second and then i roll into it in third, but it quickly comes loose and i let off. About 17psi in tires.
https://youtu.be/nTOkZppxqQI You cant tell in the vid, but it comes loose so much that you cant recover. Now I have it turned down enough to where its still spinning some but its going straight and you can stay in it.
03-18-2021, 09:39 AM | #5 | |
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
03-18-2021, 10:06 AM | #6 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Nice problem to have! But, I agree- I think it’s a corner a lot of us build ourselves into. The truth is if more attention would be made to weight, gearing, suspension, etc., there really isn’t a need for anything under the hood. These cars make plenty of power.
03-18-2021, 12:57 PM | #7 |
That depends on what you want to do. A stock engine won't get you a 10 second 1/4 no matter what you do. I wanted a well rounded car. 1g+ lateral, 10 second quarter, runs pump gas, still has AC and a back seat.
03-18-2021, 02:38 PM | #8 |
Drives: T Join Date: Mar 2015
what type of rear end and gear are you running out back on the car? maybe something a tad taller is in order on the street for you.
03-18-2021, 02:55 PM | #9 |
2&THEHIT
It’s been done...
https://www.camaro5.com/forums/showthread.php?t=586858 |
03-18-2021, 03:31 PM | #10 | |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 Join Date: Jul 2012
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-18-2021, 03:57 PM | #11 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Note the license plate...
03-18-2021, 04:53 PM | #12 |
400HP used to be enough..
Drives: 2010 2SS rs manual Join Date: Aug 2009
Has anyone tried tuning the traction control tables? I added about twenty percent to those and leaving the traction control on. Spins just a little, but doesn't get out of control. This is on my Huron twin turbo manual trans car.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
03-18-2021, 10:31 PM | #13 |
Boosted Moderator
LMAO.... What is this traction thing you ask about...
To my knowledge there is no such thing on the street..... Coilovers, trailing arms, toe rods, bushings, etc... Nine inch with 3.07’s behind a manual transmission and breaking tires loose in any gear but 6th is as easy as putting her in boost... No clutch dump needed... Can’t do it in 6th as it’s a stock gear and can’t hang... 1-5 are billet... If I really need traction, anywhere, I dial up the ProEFI traction control and let it do its thing... It keeps the “pointy” end forward most of the time...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
03-18-2021, 10:57 PM | #14 |
Drives: 2010 1SS LS3 Join Date: Aug 2019
I have to roll into 4th. Not enough road for 5th, so I don’t know. It’s a fun problem. Makes me smile
2010 CGM 1SS
408/4L80E/ZL1 ESS G4 |
