Old 05-19-2011, 09:49 AM   #1
choppah
Drives: New Camaro SS
lifter knocking
I always had a very slight lifter know when the car sat for a few days.
i would start the car and it would knock for 5 seconds and it would go away.
I only have 4,500 miles on the car and its well taken care off,now i stat it
and it knocks loud and doesn't go away. i thought i seen a TBS on the sight
a few months back.I would appreciate any input you folks have on my issue.
Thanks
William
choppah is offline   Reply With Quote
Old 05-27-2011, 12:47 PM   #2
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
My mechanic said that the L99 engines have some issues with their lifters but not the LS3 engines. Don't know if there's a TSB out for the lifters just yet or not. Might want to check that out.
Camaroshark is offline   Reply With Quote
Old 05-27-2011, 01:33 PM   #3
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
tsb or not, peeps have been getting their noisy lifters changed out on warranty for their ss's. but i'm pretty sure there is a tsb just don't know the #.
nancygrl is offline   Reply With Quote
Old 05-27-2011, 03:08 PM   #4
TAPSHIFT
TAPSHIFT's Avatar
Drives: '11 IBM 2SS/RS '16 1GB Z51 ragtop
TSB
Been there, done that.
If you have the L99 here are the numbers for the lifters and the updated valve cover and PCV tube. You might as well do both if you're taking it in. The Valve rocker arm cover-left side and PCV tube are not actually on a TSB but there is a known issue with the original versions allowing excessive oil consumtion. In my case I was seeing black smoke from the exhaust on a cold start. I suspect this is the reason so many owners have resorted to Oil Catch cans.
Lifters-#10-08-01-007C
#PI0104B Valve Rocker Arm Cover - left side part # 12570427 / PCV tube - part # 12617139
TAPSHIFT is offline   Reply With Quote
Old 05-27-2011, 03:17 PM   #5
swansor
swansor's Avatar
Drives: 2010 2SS ABM
Send a message via ICQ to swansor Send a message via Yahoo to swansor
Post 21
http://www.camaro5.com/forums/showth...ght=lifter+tsb
swansor is offline   Reply With Quote
Service Issues The IOM Ninja Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 04-28-2011 08:30 PM
Front End Knocking Noise Dave Sparkes Camaro Price | Ordering | Tracking | Dealers Discussions 4 04-14-2011 07:06 AM
AFM: how does it works? tommygun6644 5th Gen Camaro SS LS LT General Discussions 9 02-28-2010 03:36 PM
L99 Delete Whats involved? jsharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 59 05-26-2009 10:54 PM
L99 AFM -- It's REALLY a tough choice, for some. Step Inside. 2KZ28_For_Now 5th Gen Camaro SS LS LT General Discussions 128 04-03-2009 04:03 PM
