11-24-2015, 04:30 AM | #1 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
Removing Engine From ZL1
If someone need to remove the engine from their car, would you pull it out the top or would you have to drop it out the bottom?
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
11-24-2015, 07:01 AM | #2 |
Drives: '21 ZLE A10 Join Date: May 2012
you can pull a fifth gen motor from the top, if you don't have a lift. I know this because I have done it. It is much easier if you have a tilting device. Here are two pics. Removing the heads may not be necessary but it helps. I didn't remove the hood either.
11-24-2015, 02:12 PM | #3 |
Well, I suppose it would be easier pulling an engine from a Z-28, because of there not being a supercharger in the way. I did mean specifically from a ZL1, as that is what I have now. As opposed to the 67 SS I traded it for.
OHIO |
11-24-2015, 02:15 PM | #4 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
Probably only takes a few mins to pull the blower off though
11-24-2015, 03:13 PM | #5 |
Drives: 2013 Camaro ZL1 Victory Red A6 Join Date: Aug 2013
mine was recently pulled and done from the top
11-24-2015, 05:11 PM | #6 |
no differences...it would be necessary to remove the supercharger before engine removal. It is still an LS motor so it is dimensionally the same.
11-24-2015, 10:54 PM | #7 |
Drives: 2013 ZL1 Triple Black, 2015 2LT/RS Join Date: Apr 2012
Based upon the responses and photos, never having done this, it looks like either under or over will work, but based upon Stephen's input, more engine disassembly would be needed to take it out from the top, hood removal step understood, so as I'm understanding things it may depend upon the extend of the engine mods that are intended to be made once it has been taken out...
11-25-2015, 07:04 AM | #8 | |
Drives: 2013 ZL1 Join Date: Jan 2015
2013 A6 ZL1
11-25-2015, 08:00 AM | #9 |
Drives: 2015 ZL1 Blue Velvet Metallic Join Date: Mar 2015
+1
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
11-25-2015, 08:35 AM | #10 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
