03-14-2011, 10:54 PM | #1 |
Drives: 2010 Camaro 2ss/rs ls3 Join Date: Aug 2010
Need help
I just got a set of Arh headers 1 7\8 should i get the x pipe or try to hook it up to the stock h pipe and slp loudmouth axel back for now. Was not sure of the hp gains between the two and if so what x pipe should i go with. I cant find the Arh x pipe sold seprate pls help.
Thanks.
03-15-2011, 12:44 AM | #2 |
Blowin the doors off!
Drives: A 2013 SS RS 6M SR Join Date: Apr 2010
You should be in the ballpark of a 25 WHP gain and around 40 with a CAI...Could be less... but I'll throw that out for a ball park...
Can't help you too much with the x pipe, that will mostly improve your flow and sound. Because of no back pressure, you might loose a slight amount of low end torque.
2G1FS1EWXD9163847 |
03-15-2011, 01:21 AM | #3 |
Drives: 2011 2SS 6-speed Join Date: Dec 2010
I just put on a complete system from Kook's 1 7/8 headers X-pipe and full cat back with a roto-fab CAI. I have not done the dyno tune yet but plan to this week. The car feels a lot faster from start to top end. I don't know what the gains are but I'm verry happy with it. The car sounds nice at idle and cruising speed and great when you get into the high RPM's. I did not try it with out the X-pipe so I'm not sure how much of a difference it makes or doesn't make I just know i'm happy with how it came out.
