10-23-2015, 03:21 PM | #1 |
help weird squeak
So I took my 2013 1le to the dealer due to a weird squeaking coming from the rear end while cruising. It does not happen during acceleration or braking. Usually only cruising at slower speeds. It sounds like it is squeaking as the wheel is rotating. They told me my power steering was bad so they replaced it and said everything should be good now. On the drive home there goes the squeaking again. Any help appreciated or tips on what it may be.
2013 1LE SOLD
2018 SS CURRENT |
10-23-2015, 03:37 PM | #2 |
Drives: 2011 1LT Join Date: Mar 2012
The possibilities of a squeak that corresponds to wheel speed are numerous. Some of the TOP guesses might be:
---brake/ rotor issue (can you alter the sound by lightly applying the brake and/ or parking brake?) ---something bouncing around in the trunk: spare tire, or box of basketballs? Does the sound change depending on whether your road surface is mirror- smooth vs. bumpy? ---U-joint/ driveshaft ---axle boots ---wheel bearings |
10-23-2015, 03:42 PM | #3 | |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
I had a weird sound that was hard to pin point, replaced a lot of parts under warranty, ended up being the drive shaft "hanger bearing".
10-23-2015, 03:44 PM | #4 |
thank you my guess is one of the bottom three you listed.
2013 1LE SOLD
2018 SS CURRENT |
10-23-2015, 03:48 PM | #5 |
Thats next on my list. I already have multiple videos in which you can hear the squeak.
2013 1LE SOLD
2018 SS CURRENT |
