12-31-2012, 03:37 AM | #1 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
Quick Question about Solo
Okay so I don't want to do long tube headers because of the rasp they produce. I like the exhaust tone I have right now but could go for a little more growl if it happens. But my question is simple. Does anyone know the gains for solo's high flow cats?
12-31-2012, 05:46 AM | #2 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Solo claims a straight up 15hp with their HFC's on the LLT (and LFX).
They will bolt right up to yer stock exhaust manifolds and improve your sound immediately. The included (attached) resonators prevent them from having any harmful effect on the sound of whatever other exhaust components you're running- but you will definitely have a deeper growl! |
12-31-2012, 01:07 PM | #3 |
Looking at your sig, I see u were able to pair the jba with the solo. How was that? Was it hard to do or can it be done? Did u feel the increase with the solo? I want a little more power but dont think I want longtubes.
12-31-2012, 10:50 PM | #4 | |
01-01-2013, 07:40 AM | #5 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
I'm sure you know that the claims that the vendor state are typically best case increases over a stock install. The mods added to your car don't just add up. I was told by the guys in Tonawanda, where solo does their installs, that I MIGHT see a 5-8 HP increase on my setup if I add th HFC. I'm running the IPF SC with the solo Mach w/j-pipes, no resonators. This is probably the next install I plan on doing this spring.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
01-01-2013, 01:39 PM | #6 |
Yes, I know the gains don't stack up. I just wanted to see if they had any dyno sheets or anything. $700 is a lot to pay even for 15 hp
01-01-2013, 02:28 PM | #7 | |
I don't have drop springs and have had no issues. I've seen the 15hp claim from Steve at Solo a couple of times- I expect he's got a graph to back it up. Check GOINGSOLO2 in the V6 bolt-on classified's. |
01-01-2013, 03:18 PM | #8 |
Drives: 2011 Camaro RS 2LT Join Date: Jul 2012
Can you connect these solo high flow cats to JBA or Doug Thorley Shorty headers?
01-01-2013, 03:20 PM | #9 |
That's what he just posted about
