05-18-2011, 08:36 PM | #1 |
Butter Bar!
Drives: 2011 SS, 1998 Trans Am Join Date: Dec 2010
Small Red SS for Heritage Grille
I just installed my heritage grille and it looks great, but I wanted to find a way to reuse the stock emblem as I think it would look good with no bowtie and an SS in the lower left corner. It looks like the stock one is a little too small to be mounted. Does anybody know if there are any aftermarket emblems for this? I can only find the ones for the center of the grille.
Here's a pic of what I mocked up, but couldn't some up with a way to mount it.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension 2004 GSXR 1k, Matt Mladin Edition |
05-18-2011, 08:49 PM | #2 |
owner/operator VIN 1760
I used a piece of aluminum angle iron. I painted it flat black and used 3m emblem tape to stick the ss to it and it to the grill.
"With Great POWER comes Great Responsibility" - Stan Lee |
05-18-2011, 08:57 PM | #3 |
Drives: aqua 2ss l99 Join Date: Jun 2009
bump it up a notch, once the bumper is on the emblem just looks too low cause your looking down at it.
i reused my stock ss as well, i filed the plastic ss backing to the width of the heritage "fins".
May your exhaust note, sing in harmony with your blower.
05-18-2011, 09:11 PM | #4 |
Drives: SLIVERICE Join Date: May 2011
I got mine from here http://www.cleancutcreations.com/ it has 3m tape on it works great
05-18-2011, 09:14 PM | #5 |
i also used some 3m "black" acrylic foam tape.
05-18-2011, 09:19 PM | #6 |
Drives: Camaro GT Join Date: Dec 2009
sparks restorations makes a billet ss emblem for the heritage. i'll post pics on friday when my car is finished...
05-18-2011, 10:04 PM | #7 |
Drives: 2010 IBM 2SS/RS Join Date: Apr 2010
The sparks one is for the center.
I think that most people mount the stock SS back on somehow. You can use the 3m tape to stick it to the front of the fins. Mine was done for me when I first got my grill. You can cut the stock backing bracket to fit between the heritage grill fins, then you can epoxy or tape that in place. Whatever you choose make sure you scotch tape it in place first to check how it looks. The grill has a downturned angle and if you mount it the wrong way it may look more downturned. If you have to mount it infront of one fin make it the lower of the two |
05-19-2011, 09:52 AM | #8 | |
Butter Bar!
Thanks for the idea guys! I will try to file down the stock mounting bracket and use that. If it doesn't work then I'll look into those emblems.
You're saying move it up one block on the grid? Thanks for the tip.
05-19-2011, 11:03 AM | #9 |
C_H_E_V_Y
Drives: Velocity Yellow C6 Z06 Join Date: Jan 2010
I Used a small piece of plastic and fitted it to the grill and then painted it black then mounted that to the Heritage Grill and then Mounted the SS Emblem to that, Looks great and you cant see the plastic peice.
Heritage Grill Flat Black Full Body Stripes Flat Black Tail Light Bezels Flat Black Camaro Emblems Flat Black / Red SS Emblems Flat Black Side Markers Chevy Bowtie Delete Led Grill Lighting Interior Led Lighting Near Future ( 1'' Drop Springs, GFX and *headers,Xpipe and 3in catback with an CAI is on it way* Getting ready for the PROCHARGER ) |
Similar Threads | ||||
Heritage Grille SS emblem, old skool | MR. FBDY | Camaro DIY & HOW-TO instructions & discussions | 27 | 09-22-2013 10:27 AM |
Added Red Pin Stripe, and did red 69 SS in front and back lemme know what ya think | 2SSRS-CGM | Cosmetics and Lighting Modification Discussions | 30 | 12-14-2010 07:26 PM |
Do you want the Z28? | ChrisB | Camaro ZL1 Forum - ZL1 Specific Topics | 1616 | 09-04-2010 11:49 PM |
White SS badging RED SS Badging??? | 1BADZL1 | 5th Gen Camaro SS LS LT General Discussions | 19 | 06-25-2009 01:00 AM |
Camaro Commerical (Yellow RS, Red SS) | SGOS252382 | 5th Gen Camaro SS LS LT General Discussions | 8 | 04-09-2009 09:59 PM |
