09-01-2016, 03:45 PM | #1 |
Drives: 2013 Camaro 1LS - Ashen Gray Join Date: Jan 2015
lf3 fuel pump part #
hi - anyone know the part# for the lf3 hpfp... has anyone ever founf out if the lf4 hpfp is an option or not?
"WIDOW" Overkill Edition w/Mace Cams,80mm tb,Jacfab spacer/ported intake,Alky Control,ARH off road pipes,SOLO custom system,3.91 gears, MGW,Phantom grilles,ZL1 appearance pkge, 3dCarbon vents, Lingenfelter hood and spoiler, PLX boost/wideband modules/gauge,ZL1 fuel pump,LF3 hpfp,DSS aluminum driveshaft,JPSS sway bars, Z28 replica wheels and CxRacing coilovers..
09-01-2016, 04:18 PM | #2 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
I dont think it works-pretty sure Gretchen had to have his built with a Ferrari part or something of the sort
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
09-01-2016, 04:27 PM | #3 |
hi Derek - I spoke to Aaron over @ GPI and lf3 works but you have to measure the difference between in height between the lifters(the lf3 wont fit) and add a hardened spacer on it to make up the difference for it to work... we have plenty of injector at #109 lbs but without getting more volume from the hpfp looks like e85 is not going to work
09-01-2016, 04:28 PM | #4 | |
Ill be watching this! Ill do some research as well
Sponsors:
09-01-2016, 04:54 PM | #5 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
The part number I had was 12658270
its still listed on GMpartscenter.net and shows its for the LF3 Vsport Cant find the part number for the LF4 pump... would probably have to go to the dealer to look at diagrams to find it. |
09-01-2016, 05:09 PM | #6 |
Found one on Ebay for a decent price if you are wanting the LF3
http://www.ebay.com/itm/CTS-NEW-2014...pXcXvX&vxp=mtr
Sponsors:
09-01-2016, 06:40 PM | #7 |
12652441 is part for lf4..... Trying to see if they are compatible...
09-01-2016, 08:15 PM | #8 |
Keep us in the loop
I'll be in the same boat as you in a week or so Sent from my iPhone using Tapatalk
Sponsors:
09-01-2016, 09:05 PM | #9 |
I bought the one off eBay you found Derek ...nice find and thanks to you and Jason on the part number again... I think I still need to round up a gasket and follower
09-02-2016, 02:44 AM | #10 |
Awesome
Lemme know what you find out !!! Sent from my iPhone using Tapatalk
Sponsors:
10-17-2016, 07:18 PM | #11 |
Built Not Bought
Drives: 2010 Twin Turbo LFX Join Date: Jun 2016
any update on this ..derek or DGM
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014 "Built Not Bought!' Sponsors: OverKill Motorsports |
10-19-2016, 09:12 AM | #12 |
testing it now with e85 and then pump gas.... initial feedback with e85 is not good, the 30% fueling margain with e85 might be too much to overcome... it has made improvements with pump gas in past and I was on the lean side above 6300rpms and using methanol to carry it the rest of the way.. so will test that next
10-21-2016, 09:04 PM | #13 |
Built Not Bought
keep me updated
2010 Twin Turbo LFX
Thread Tools | |
