02-04-2019, 03:28 PM | #1 |
Back4Revenge
Has anyone with a Supercharger ever pass obdII emissions?
Supercharger on a V6 LLT with longtube /hi flow cats (Illinois Chicagoland Area)
I installed mini cats / extenders but not sure which codes enabled or disabled can prevent the catalyst monitor from readying up. Right now I get p0102 because of the s/c
I chose my 6 with Pride..
02-04-2019, 04:46 PM | #2 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
I pass here in NM, though I have shorties with stock cats. My tune has the rear O2 sensors disabled.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
02-04-2019, 06:01 PM | #3 |
I pass every year here in NC.
02-05-2019, 02:23 PM | #4 |
Back4Revenge
SS's have no problem but the v6 tuning does.
02-05-2019, 06:49 PM | #5 |
P0102 is a MAF sensor code. Do you have a blade style MAF card or does the V6 utilize a MAF that is molded into part of the intake tube?
02-06-2019, 02:21 PM | #6 |
Back4Revenge
Blade for sure with the Overkill kit
