11-09-2011, 01:08 PM | #1 |
Drives: 2010 Join Date: Sep 2009
Does anyone have a link or photo of the ZL on a lift to see the suspension driveline
I want to see if GM changed things under this ZL and all the 2012 cars in regards to bushing size, control arms, etc.
Does anyone have a photo or link that shows this? |
11-09-2011, 01:26 PM | #2 |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
I believe on one of the videos there was shots of the undercarraige and they discuss some of the upgrades for the ZL1. Go to the photo and video compilation thread and I think it is the 24 hour testing video.
11-09-2011, 01:34 PM | #3 |
knows 2 facts about ducks
Only thing you can see on the underside is the under belly cover.
11-09-2011, 02:01 PM | #4 |
Downright Upright
Drives: Daily Join Date: Apr 2009
TMK, those who've had access to the cars on a hoist are NOT to speak/photograph...yet...
11-09-2011, 02:09 PM | #5 |
Petro-sexual
There are only glimpses of the rear, like the differential sump and cooling lines, and bits of the exhaust here and there. You just have to watch the videos GM's made and try to get them from those.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
11-09-2011, 02:49 PM | #6 |
i figured they had these test mules all over at events in the USA i wondered if anyone crawled under and snapped some photos.
i really need to see whats done under this car to see if GM corrected a pretty major design flaw from the first few model years of the 5th gen. |
11-09-2011, 02:51 PM | #7 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Why not just ask your question about the design flaw and see if you can get an answer from anybody? Can't hurt?
11-09-2011, 03:21 PM | #8 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
Spill the beans, what's the flaw?
11-09-2011, 03:32 PM | #9 | |
2. Look at the number of low mile cars modified on the market, wonder why? I spoke to well over 80 owners and they all said that's why they were selling. 3. Most owners will never experience this issue or drive well beyond 100+ its a bad driveline vibration from the negative angles of the diff and axles. when you mod the cars or lower them it becomes worse, stiffer bushings also make it worse as do larger tires. Axles seem to break Outer CV even aftermarket ones, driveshaft couplers wear and break and even suspension bolts over time become loose. every race car has this issue. GM really messed up and I want to see what and how they mad the ZL1 into what it is. GM knows of this problem since I have spoken to engineers since 2009 and said they planned to fix for the 2012+ models. So once i get a chance to see a ZL1 in person I will immediately know what they changed. |
11-09-2011, 04:51 PM | #10 | |
Drives: Waiting for the 2013 ZL1 Join Date: Apr 2010
Now this way, people will see he was in fact looking for answers to a real problem. (It happens a lot with the valve issue in the Zo6 forums, a guy comes across to harsh, and no one replies with any helpful answers) |
11-09-2011, 04:55 PM | #11 |
Downright Upright
This is PRECISELY why Holden and G8 suspension guys suggested the maximum lowering of this vehicle be kept to 12-15mm...or roughly 1/2".
Who listened? |
11-09-2011, 05:16 PM | #12 |
I know that they moved the rear swaybar connection outward, the rear cradle bushings are stiffer and the lower rear control arms are beefed up. I have the rear craddle bushings and swaybars on my car and don't have any vibration.
11-09-2011, 05:28 PM | #13 |
I wonder why mine didn't ever have this problem. I have stock - diff updraded gears, driveshaft, all stock bushings, aftermarket axles and it was even lowered for a bit. I have made hundreds of passes down the track at 130-145 with quite a few very hard launches and plenty with over 1000 rwhp. All stock gear underneath except shocks and a chassis brace. I even drive it over 100 all the time on the highway no problems. I have a radar laser jamming system too.
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout 2011 2nd Place Fastest 4 5th Gen LSX Shootout Last edited by paul2010; 11-09-2011 at 05:47 PM. |
11-09-2011, 06:01 PM | #14 |
exactly if GM even raised the subframe up an inch or 2 these issues would never occur its the way the trunk floor is laid out and the provisons for a fold down seat and trunk space limited what they could do with the parts bin G8 subframe.
Similar Threads | ||||
Cam basics | CamaroSpike23 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 76 | 11-25-2015 11:42 AM |
Pfadt Camaro Rear Toe Link Reinforcement Kit Install write-up | PfadtRacing | Suspension / Brakes / Chassis | 9 | 01-28-2014 07:15 PM |
Looking for a car lift | torquepower85 | Off-topic Discussions | 30 | 09-02-2013 05:37 AM |
Looking for a car lift | torquepower85 | General Automotive + Other Cars Discussion | 3 | 09-11-2010 07:49 PM |
Camshaft Basics | Milk 1027 | Wiki | 1 | 12-09-2009 12:00 AM |
