02-20-2015, 11:48 AM | #1 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
Are squeegees bad for glass?
Something occurred to me yesterday. We strive to keep our glass as smooth as the rest of the car. For obvious reasons, I'd never use a squeegee (or even a water blade) on my paint, so should that apply to glass as well? Granted, glass is harder than clear coat, but if a piece of debris were to get on a squeegee I'd guess it could probably still cause a scratch. Am I just being paranoid?
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
02-20-2015, 11:55 AM | #2 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
Your are not being paranoid as what you ask is true- a piece of debris on a squeegee could scratch the glass.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
02-20-2015, 11:59 AM | #3 |
Drives: 2014 Camaro 1LT/RS Join Date: Sep 2013
I don't use one. But I don't know what debris you would get in the squeegee after a wash that would harm the glass...
I would be more weary of the squeegee stripping away any sealant.
Detailing is an involuntary obsession.
02-20-2015, 01:11 PM | #4 |
OK, the squeegee's gone, but sealant? Stupid question time: does glass have sealant on it, or are you talking about an aftermarket application (or both)?
02-20-2015, 01:20 PM | #5 |
650HP soon to come
Drives: 2017 Chevy Camaro ZL1 Join Date: Jul 2011
Aftermarket application such as rainx or Adams glass sealant.
2017 Camaro ZL1
Hyper Blue Metallic A10, PDR, NAV, Premium floor mats |
02-20-2015, 01:36 PM | #6 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
I imagine a squeegee is no worse than the wiper blades (that's what they are).
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
02-20-2015, 02:02 PM | #7 |
That's why I say that. You can always tell where the wiper blades wipe because the beading of water is different between the two areas.
02-20-2015, 02:19 PM | #8 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
I use a squeege to get the water off the windows for years and it never scrached. I also have never used the gas station squeege. Those things are bad enough to scratch diamonds.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
02-20-2015, 02:53 PM | #9 |
Drives: The shiny ones. Join Date: Mar 2010
Potentially? Sure.
Likely? Not really. It would take some pretty serious grit and a lot of force behind the squeegee for that to be an issue IMHO. I just choose not to use one b/c its just as easy to wipe the glass with a drying towel while I'm drying the rest of the car vs. carrying a squeegee just for the glass. |
02-20-2015, 05:00 PM | #10 | |
The Adams shampoo leaves the glass spotless! |
