02-23-2012, 11:23 AM | #1 |
Resident Cynic
Drives: "Shakira" 2010 Camaro 1LT V6 Join Date: Jul 2011
Getting a CEL after DT shorty install
I'm just curious what you all think may be the cause. Got new oem gaskets on, everything runs great, no odd sounds. EZ flash also scans codes right? I was going to check on this after work, do a datalog, etc.
Will keep updated as results present themselves.
Current Mods- Injen CAI, Trifecta tune, Doug Thorley shorties, MRT v1 w/ res delete, 20" Boss 338's (Grey), SS Bumper, Heritage Grill, Pfadt Racing Lowering Springs
Upcoming Mods- MPD1 Spoiler Planned Cosmetic Mods- Modern Yenko Stripes, Window Tint |
02-23-2012, 11:37 AM | #2 |
Did you disconnect the harness that goes into the throttle body? That will cause a CEL on some cars which can be cleared with EZFlash or just disconnect the battery for a minute.
Check the welds, make sure the O2 sensors are firmly plugged in. You'd be the first to get a CEL from the DTs, so I suspect it won't return after clearing the codes. I ran them for the better part of a year and had no issues. I think you'll be ok, just clear the codes and see if they come back.
[B]
02-23-2012, 11:59 AM | #3 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Dreams is right...if it is an CEL from an 02 sensor...you'd be the first I've heard of getting that. Something is going on here.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
02-23-2012, 12:05 PM | #4 |
Resident Cynic
Nothing seems out of ordinary. Ez-flash DOES read codes does it not?
02-23-2012, 12:16 PM | #5 |
Resident Cynic
Called the shop that installed them. They are happy to double check all their work. After that if theres still an issue ill see what the code is all about.
02-23-2012, 02:56 PM | #6 | |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Also its not unusual to need to re-torque the header bolts after initial use. Good luck! Keep us posted ... |
02-23-2012, 09:09 PM | #7 |
Resident Cynic
P0056 Dev: 05E8 History SES Current Stored Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
O2 Sensor need replacing? All you car nerds HALP!!
02-23-2012, 10:16 PM | #8 |
That's the 2nd sensor, passenger side- should have been far enuff away from the weld. Maybe just got a shock! Re-set it if you haven't already.
I'm hoping it won't come back (bet you are too!). |
02-23-2012, 10:48 PM | #9 |
Resident Cynic
I disconnected the negative post yesterday for a good 10 mins...went away and came right back
02-25-2012, 01:38 PM | #10 |
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
Check to make sure they plugged it in and the wiring wasn't damaged. Wouldn't be the first time a code was thrown for a bad connection.
Good luck and I'm doubting it's a DT issue.
I wake up in the morning and I piss excellence.
-Ricky Bobby America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936 |
02-25-2012, 03:41 PM | #11 |
Resident Cynic
We shall see. I'm not stressing it much as it doesn't seem to be affecting anything (according to ear and butt dyno). Work is keeping me pretty well tied up lately. Will probly take it in to be checked on the 6th unless someone more knowledgeable suggests otherwise, as I'm personally clueless as to the ramifications of rolling with a bunked O2 sensor.
02-29-2012, 09:49 AM | #12 |
Resident Cynic
Update: called the dealership and they said I should still be under warranty for this. Hopefully they don't change their mind when they see the DTs.
Sent from my MB860 using Xparent Red Tapatalk
02-29-2012, 08:09 PM | #13 |
Rear O2 sensors are not used to adjust anything, they're there to ensure the cats are working properly in the system, so your car should still be running fine. If the welds are fine and the O2's aren't damaged and still plugged in, you may have just a part that failed?
03-09-2012, 12:44 AM | #14 |
Resident Cynic
Final update, new O2 sensor in, no cel. All is well!
(covered under warranty even with my mods!) Sent from my MB860 using Xparent Red Tapatalk
Similar Threads | ||||
CEL P0056 after wideband install.. | bmorecam | 5th Gen Camaro SS LS LT General Discussions | 1 | 10-31-2011 06:28 PM |
Doug Thorley shorty headers install! | topgun1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 30 | 05-27-2010 11:27 PM |
CEL Code after Supercharger Install L99 | DarkNight | Forced Induction - V8 | 9 | 05-06-2010 04:30 PM |
Exhaust gaskets for Shorty Header install | HeavyD | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 11-20-2009 02:37 PM |
DIY : Install catback on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 3 | 08-09-2009 04:36 PM |
