02-16-2013, 05:48 PM | #1 |
Drives: 2011 2ss blk on blk convertible Join Date: Aug 2012
convertible piller gouges
I cant seem to find pillar gouges for my camaro...everything I've seen is for the hard tops....can anyone help me out. ....thanks
02-16-2013, 07:20 PM | #2 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
I couldn't find a pillar to match the fake cf on my T3 version either, so I got a single SLP column mount pod for my WB O2.
02-16-2013, 07:40 PM | #3 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
There's a forum member on here who said he took an AEM pillar and mated it to his original pillar. If you look in the convertible section, you'll be able to find him. His avatar pic is of his orange convertible. I'm in the same boat too as you.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
02-16-2013, 08:46 PM | #4 |
Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
Thats why I got the ADM gauges that fit right below the speedometer. Best way I found to mount gauges in a convertible.
02-16-2013, 09:19 PM | #5 |
I can't do that. When I had my meth kit installed, they put the two LED's right there. I think I'm gonna try using a stand gauge pillar.
02-16-2013, 09:40 PM | #6 |
Here's the thread that I was talking about. I just found it. He used Autometer.
http://www.camaro5.com/forums/showthread.php?t=276675
