06-09-2012, 12:46 AM | #1 |
Drives: 10 Procharged SS Join Date: Oct 2009
116 Separate Fuel Cell for an FI engine
If i was to put a separate fuel cell in my car for 116 how could i tie it into the fuel lines i already have that are being pumped using LPE twins? Would it needs its own fuel pump?
06-09-2012, 07:42 AM | #2 |
Drives: CGM,twin turbo, cam 2010 SS/RS Join Date: Mar 2011
You will need a y fitting or block fitting. Yes it's on fuel pump. If you going to do that you Need to run a return line and a regulator. What are you trying to do? What kind of FI? Hoe much hp?
06-09-2012, 08:03 AM | #3 |
I will have 2 separate tunes. One for 116 and one for 93. I want a completely separate tank to house the 116. Maggie, 700rwhp and 766 rwtq
06-09-2012, 08:33 AM | #4 |
Last time I was in illinois I noticed you guys had some e85 stations any near you?
06-09-2012, 08:41 AM | #5 |
Got them all over the place. With E85 im assuming to get maybe 2 degree's out it. With 116 should be able to get 4 or with some fingers crossed a little more. Im still researching it a lot and E85 isnt completely out of the question.
06-09-2012, 02:35 PM | #6 |
Drives: 2004 GMC Join Date: Sep 2010
Don't know if cost is a concern, but there's obviously a HUGE difference in price! If was me, I personally wouldn't waste my money on 116 race fuel. I have an 11:1 370/l92 with TVS1900, and I am going to run E-85 as soon as I finish my fuel system.
06-09-2012, 11:45 PM | #7 |
What do you need to run E85 (different injectors)?
06-09-2012, 11:53 PM | #8 |
Tune and 30% more fuel. So prob injectors if they aren't big enough.
06-09-2012, 11:54 PM | #9 |
Ive got 65lb injectors now withe LPE twin pumps. With those work?
06-09-2012, 11:58 PM | #10 |
No. Way to small. I would be running a bigger injector than that with the hp you have now on pump gas I doubt the pumps are big enough either.
06-10-2012, 12:00 AM | #11 |
Let me check with my builder. I my have bigger injectors than that
But if it comes down to it all i need is bigger injectors and obviously a tune? |
06-10-2012, 12:02 AM | #12 |
Drives: ZL1/TBSS/COPO Join Date: Apr 2012
Why not just do a pure meth system. It will make you pump fuel 116oct when needed and your fuel system can just stay put.
.....2012/14 COPO #33....427, 1.31 60' ....9.39@143......
06-10-2012, 12:03 AM | #13 |
I don't know if your pumps will work you should talk to lpe about that I don't know much about their set up. I'm guessing no they aren't big enough at all.
06-10-2012, 12:29 AM | #14 |
The pumps are plenty big enough the injectors im not sure of. I do plan on running meth, but i think we will run both E85 with meth injection. I have 4 E85 stations within 20 miles and its also nothing a few jugs from jegs cant take care of when going to other states for drag racing.
