03-08-2013, 01:22 PM | #1 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Has anyone put in just 1LE axles and not the 1LE hubs?
I'm putting in 1LE gears and axles. Need to know for sure that I don't need the hubs.
Has anyone actually done the 1LE axles without the hubs? |
03-08-2013, 08:31 PM | #2 |
King of All
Drives: 2014 Summit White Z28 #275 Join Date: Dec 2012
You cant do it. The 1LE axle shafts are longer. You have to have the hubs too.
03-08-2013, 09:10 PM | #3 | |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
Sent from my DROID RAZR using Tapatalk 2
03-08-2013, 09:24 PM | #4 | |
King of All
After 2 weeks of owning my car my drivers rear axle broke. The dealership quick fixed it and the shaft they had put in was not the same length and was causing the diff to leak. The axle shaft was almost pulled out of the diff. Needless to say they replaced it with the right part. Now while I dont know for sure, I gave my apparent opinion. |
03-08-2013, 10:09 PM | #5 | |
OP, you might be the first to actually try it. The problem with this forum is people pass off opinions as if they are fact. Few have any actual hands on experience.Your best best is to just use the heavier duty ZL1 hubs. I paid less than $240 for the set. Sent from my DROID RAZR using Tapatalk 2
03-09-2013, 05:21 AM | #6 |
Ok while you guys are talking, I am looking a getting a complete 3.91 1LE pumpkin. I am planning on using it with my SS axles. Is that going to work?
03-09-2013, 06:16 AM | #7 |
9691 & 97586
Drives: 2010 SS, 1999 SS, 1993 Z28 Join Date: Mar 2009
Why not just get the gears? Alot cheaper and very easy to install.... you'll need someone with some gear experience and a press to take off the and re-install the pinion bearing and the rest is pretty much slide and slide in.
03-09-2013, 07:33 AM | #8 |
If I get the entire pumpkin from my dealer I will keep my drivetrain warranty intact. Dealerships seem to not have allot of experience put in gears. If I snap and axle or anything the cost savings would be gone right away and drive train warranty would not be there if some other shop did the gears.
03-09-2013, 08:01 AM | #9 |
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
Get the dealership to do the gear install. I got a quote for $800 installed for the 3:91's and warranty intact from a dealership.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
03-09-2013, 08:45 AM | #10 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
$800 is a very good price. Honestly I am shooting for the full pumpkin and dealer install with Livernois tune.
03-09-2013, 09:13 AM | #11 |
9691 & 97586
The warranty is all fine and dandy but if it or something associated to it breaks... the dealership is gonna replace it with what is factory installed. You'll be right back to this point again... having to buy another pumpkin if it's damaged. Basically your warranty is covering the labor charges. I just went through this with my lifters. I had a custom cam which is not associated to the lifter failure and GM warrantied the problem.... but I had to buy a new 400.00 custom cam or go back to factory which they would've covered... but that requires alot more work. Just food for thought. Don't get sold on all this warranty stuff... yes its great and certainly helps but it only covers factory installed equipment.
Sent from my Apple sued Galaxy Note 2
03-09-2013, 09:25 AM | #12 | |
03-09-2013, 09:44 AM | #13 | |
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm Join Date: Feb 2009
URR2SLO - If you're not going fast enough, get out the way......
03-09-2013, 06:54 PM | #14 | |
9691 & 97586
