09-11-2015, 11:21 PM | #1 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
Suspension / Drivetrain Advise
I have a 14 ZL1 and I'm in the process of doing bolt on mods... In all the cars I've owned suspension, strengthening, and cooling have come first before major power upgrades.
No going to do much for a while power wise till after warranty is up I'm looking for advise on strengthening rear end if needed, suspension mods that will tighten up the car but keep it streetable Ordered Jannety Billet main caps for the rear and a LPW Diff Cover with poly bushing... A6 Trans going to run drag radials ... |
10-22-2015, 10:46 PM | #2 |
Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
You may not have to do much to your ZL1 as they leave the factory a little more robust than the SS's. Your differential is good for 1,000 hp they say, and with an A6 you won't shock it as much as if you had an M6. You may not need the poly cradle bushings, toe links and trailing arms the SS needs to avoid wheel hop. Maybe only replace the parts as they break?
Meh
10-23-2015, 06:48 AM | #3 |
Since you have a ZL1 and an auto nothing is needed for the rear end of that car. I did not know that anyone made a differential cover for the ZL1 differential either along with the billet caps??
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
10-23-2015, 12:07 PM | #4 |
Team 913
I didn't do the research and bought the billet caps and the diff cover ... Told the venders I had a zl1 ... Maybe they work maybe they don't didn't take the time to install them...
Thread Tools | |
