03-24-2014, 09:01 AM | #1 |
Too much is never enough!
Difference between TSP, Kooks, and AR LT headers?
I am sorry that you are reading another header thread, but I am in the market for a set of LT headers. I have narrowed it down to these three...Kooks, TSP, and AR. Problem i am having is they all make good HP gains and basically all say that there great. while i am sure that each one is great in its own right. i am wondering what the real differences are between them and why i should choose one over the other.
I am not wanting to turn this into a "well this is what i run" or "buy from X-vendor they will treat you right" I am honestly not that interested in the headers that you run I am sure that you will recommend the headers that you are currently running, but I am really not a follow the leader type of buyer...more along the lines of the known differences between the three.. Basically price is not the issue here I just care that i buy the right set for me and my future mods...which include Super charger and cam. Thanks in advance for your help and input.
03-24-2014, 09:46 AM | #2 |
Drives: E92 BMW M3 Join Date: Oct 2012
Well for starters TSP is welded in China, and doesnt have a merge spike like Kooks, ARH, and Stainless Power(also welded in China). I am not familiar enough with these to know how they differ in their connections to cats and/or cat back exhaust, but surely someone can chime in on that.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
03-24-2014, 10:04 AM | #3 |
If price is not an issue flip a coin between ARH and KOOKS. It's a win win situation.
03-24-2014, 10:30 AM | #4 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
^^ +1
From a performance perspective, no difference at all. Only real difference is where they are made and their warranty's.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
03-24-2014, 10:34 AM | #5 | |
HTCC Member
Take a look at my link, it's on the second page..... http://www.camaro5.com/forums/showth...=275478&page=2
03-24-2014, 10:51 AM | #6 |
Thanks for the reply's.
Do any of them have fitment issues? I have heard that some sit on the plug wire itself but i cant remember which one....I thought I read about one guy having to modify his to allow for more clearance between plug wire and header can any vendors chime in on the differences between there products?
03-24-2014, 10:59 AM | #7 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Only true difference is price. Pick what moves you and enjoy.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
03-24-2014, 11:06 AM | #8 |
Let's face it, we are talking about tubes, no moving parts no rocket science... All brands have to get the exhaust gas from the same points A to the same point B in the same amount of space, so there really won't be that much of a difference in engineering. As long as they are made of 304 stainless and fit (Which applies to all that you mentioned) there really is very little difference.
I vote made in the USA, but you can do whatever you want.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
03-24-2014, 11:26 AM | #9 |
Drives: 13' 1LE Join Date: Apr 2012
China vs usa. Go for the ARH, unless you are really broke. I went with Stainless Works(usa made) , and the fit is perfect with 2" headers; steering shaft, plug wires, frame and ground clearance are nice.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
03-24-2014, 11:34 AM | #10 |
im not trying to make it out to be rocket science, nor an i trying to reinvent the wheel...and thanks i didn't realize that the point was to get gas from a to b with no moving parts.....i am just asking if and what the differences are other than 500 bucks i figured for that price there had to be something that was not the same..thanks for taking the time to post
03-24-2014, 11:51 AM | #11 | |
Seems his post was to clarify why there just isnt much room for difference on a mod like headers. For the extra $500 you get a nice name plate on it...woo hoo!
03-24-2014, 11:52 AM | #12 |
ok thanks guys i understand
03-24-2014, 11:53 AM | #13 |
Good luck with your decision, and post some vid when you are done so we can hear it!
03-24-2014, 12:09 PM | #14 |
Ok I am going with Kooks and there off-road pipes. seems as if there all the same and since there made in america and a few hundred cheaper than ARH....so thanks again everybody and once again sorry for starting another header thread.
Going to order by the end of the month and soon as I install them ill post a vid!, I cant wait.
