#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Wheels | Tires -- Sponsored by The Tire Rack
BeckyD @ James Martin Chevy
Old 12-08-2017, 09:13 AM   #1
rjacobs
Drives: none
nails in tires...
This car is a nail and screw in the tire magnet...
Anybody else have this issue?
Picked up a screw with 20 miles on the car, luckily that one could be plugged and patched.
Got in the car yesterday and air pressure was a bit low on the other rear. Got to lunch and saw a nail in the tire...and wouldnt you know, to close to the shoulder to plug and patch so im getting a new tire... 270 miles...
Discount though is selling me road hazard on all the tires for pretty cheap so I will be protected going forward. The dealer wanted like 1200 for the wheel and tire protection package so I passed... Discount is doing all 4 for like 40 bucks.
rjacobs is offline   Reply With Quote
Old 12-08-2017, 09:15 AM   #2
xp3nd4bl3
Drives: 2017 HBM ZL1 M6
5k miles and nothing here. Maybe you just had a good run of bad luck.
xp3nd4bl3 is offline   Reply With Quote
Old 12-08-2017, 09:35 AM   #3
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
I've got one but, it isn't leaking any air so, I'm afraid to try to remove it.
2018 ZL1 1LE - Red Hot, Nav, PDR
ZL1 1LE is offline   Reply With Quote
Old 12-08-2017, 09:37 AM   #4
rjacobs
Drives: none
Yea im thinking this, but man, its just hard to swallow LOL.
Man, when I see a screw or nail, I gotta get it taken care of immediately. Luckily I have a daily driver so I pull the wheel/tire off in my garage and take it to get repaired. I would NOT want to have a nail or screw I knew about come out when out and about and have to get a tow... I will never put that nasty tire goo in my tires as it basically ruins them, the TPMS sensor, etc...
Old 12-08-2017, 09:45 AM   #5
FringBirdAloha
Drives: Pre-production ZL1 M6
I drive my ZL1 only about 100 miles a month so I’ve been lucky. But my daily driver 2016 SS used to pick up nails often.
FringBirdAloha is offline   Reply With Quote
Old 12-08-2017, 09:48 AM   #6
Jmueller
Drives: 2017 ZL1 A10 Nightfall Gray
I am with you on this. If I see a nail, its coming out ASAP. I do not want to drive and risk the nail flinging out and having it come out on its own terms. I make the rules on when the nails come out!
Jmueller is offline   Reply With Quote
Old 12-08-2017, 10:13 AM   #7
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Be careful if driving plugged tires at very high speeds.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 12-08-2017, 10:18 AM   #8
rjacobs
Drives: none
plug and a patch...
I had my previous Z06 up past 170mph on a plugged and patched tire... no worse for the wear.
Old 12-08-2017, 10:21 AM   #9
Sven59
HAMMER PILOT
Sven59's Avatar
plug and a patch...
You can do that if you want, I wouldn't take the chance.
Sent from my SM-G955U using Tapatalk
Old 12-08-2017, 10:36 AM   #10
Torquem
Bannable
Torquem's Avatar
Drives: 2017 Camaro ZL1
properly plugged and patched tires do not effect speed rating.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic
Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's
Torquem is offline   Reply With Quote
Old 12-08-2017, 11:00 AM   #11
Sven59
HAMMER PILOT
Sven59's Avatar
I am glad you feel safe, I had nails in my GYs. The guy said he wouldn't track the car or high speeds. He said that once a tire has been punctured the structural integrity is in question for it's original rating. You guys can do whatever you want.
Old 12-08-2017, 11:20 AM   #12
Torquem
Bannable
Torquem's Avatar
That's straight from Michelin. But I can see both sides. YOLO!
Old 12-08-2017, 12:10 PM   #13
SociallyAwk
SociallyAwk's Avatar
Drives: '17 SS 1LE
I've had two nails. Both after buying new tires. So I had to buy more new tires.
It's a magnet.
SociallyAwk is offline   Reply With Quote
Old 12-08-2017, 01:13 PM   #14
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
If a patch plug is well installed from the inside out, the tire should be safe. We have patch plugged slicks and not had any issues. That said, if Michelin says it is bad...
