12-12-2017, 05:37 PM | #1 |
Drives: 18'-1LE Join Date: Jul 2017
Odd question...
I had a very brief ride in our 1LE, there were a few times the car seemed to be wrestling with the road, as if you really should keep both hands on the wheel.
This was hit and miss, here then gone, maybe a few hundred feet of roadway then back to normal. Any 1LE or ZL1 owners come across this? |
12-12-2017, 06:25 PM | #2 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
Tramlining on negative camber, perhaps?
12-12-2017, 06:30 PM | #3 |
Drives: 2017 Summit white ZL1 M6 Join Date: Sep 2017
I found that if the road wasn’t basically flat and I was hauling ass with the trac control ON my zl1 would do this. Turned everything off and never had an issue at 740/775 to the tire.
12-12-2017, 06:48 PM | #4 |
Ok guys, I should add that I was in snow/ice mode traveling around 35 mph.
12-12-2017, 07:06 PM | #5 |
Drives: Camaro Justice Join Date: Jun 2007
12-12-2017, 07:13 PM | #6 |
Had just left the dealer on my way to the Expel installer and it was 28 degrees outside, snowing but not sticking with just wet roads. Still the ass end was kicking out with very little throttle input.
The tires really weren't made for those conditions and I assumed this would be the most intrusive mode. Last edited by S.T.A.R.; 12-13-2017 at 06:24 AM. |
12-12-2017, 07:58 PM | #7 |
1959 Chevy Apache 4X4
Drives: 2017 ZL1 Join Date: Feb 2016
I have this issue sometimes. Now that the tires are "old", my car seems to wander sometimes. This especially happens if tires are under inflated a couple of pounds.
I've been told that this is just part of having very wide tires... IDK
2017 ZL1 garnet red/A10/nav/pdr/sunroof/CF hood insert
1100 2-1-17 2000 2-14-17 3000 2-15-17 3000 TPW 3-13-17 3300 3-6-17 3800 3-13-17 4B00 3-13-17 4200 3-15-17 4800 3-22-17 5000 3-27-17 6000 3-28-17 Last edited by stella16; 12-12-2017 at 11:16 PM. |
12-12-2017, 10:18 PM | #8 |
Drives: 2017 ZL1 silver A10 Join Date: Jul 2017
My regular ZL1 does this bad on rutted roads.
12-13-2017, 06:16 AM | #9 |
12-13-2017, 06:21 AM | #10 |
12-13-2017, 07:13 AM | #11 |
It has only really bothered me a few times, on those occasions it felt like the electronic power steering was fighting me. It really is road surface dependent.
12-13-2017, 08:44 AM | #12 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
I had it occasionally with the GYs. Very rare with MPSSs.
Sent from my SM-G955U using Tapatalk
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
12-13-2017, 08:48 AM | #13 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
Not in my experience with MPSSs.
2018 ZL1 1LE - Red Hot, Nav, PDR
12-13-2017, 08:48 AM | #14 |
