Old 02-10-2011, 07:25 AM   #1
JAB
C_H_E_V_Y
JAB's Avatar
Drives: Velocity Yellow C6 Z06
Issues with forced induction ?
I'm looking into supercharging my L99 SS with a whipple charger or tvs2300, headers, cam and forgeinternals to get around 600 to the wheels, My question for y'all with SC or anything similar do y'all run into problems all the time or engine problems, I just don't wanna void my warenty and then be forking out masses of money all the time to fix it when things go wrong.. So if it's done by a professional and all tuned up correctly and what not can I expect it to be pretty reliable or problems ahead ?
Heritage Grill
Flat Black Full Body Stripes
Flat Black Tail Light Bezels
Flat Black Camaro Emblems
Flat Black / Red SS Emblems
Flat Black Side Markers
Chevy Bowtie Delete
Led Grill Lighting
Interior Led Lighting
Near Future ( 1'' Drop Springs, GFX and *headers,Xpipe and 3in catback with an CAI is on it way* Getting ready for the PROCHARGER
JAB is offline   Reply With Quote
Old 02-10-2011, 07:50 AM   #2
JJ2010
Drives: 2010 Camaro SS
My l99 has been supercharged for almost 1 1/2 years no problems....
The tune and how you drive it will make all the difference.....
JJ2010 is offline   Reply With Quote
Old 02-10-2011, 07:56 AM   #3
ron10
Drives: 2010 2SS IOM L99
i know guys that have sc cars and have had no problems.of course there are no guarantees.
Old 02-10-2011, 07:56 AM   #4
old motorhead
Drives: Maggie blown LS3 vette
With the TVS, if your tune is right, you have plenty of fuel, and that fuel quality is consistant, you won't have a problem with the motor (at those power levels). The rest of the drivetrain might not fare so well though. At 600 wheel, you're looking at upgrading lots of stuff behind the motor. Back your power goals off a hundred hp or so and you'd still have a fun ride and you might get away without upgrading the rest of the drivetrain. Your choice. More speed takes more $. How fast do you want to go?
old motorhead is offline   Reply With Quote
Old 02-10-2011, 07:58 AM   #5
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Call and ask the boys at GMPP. If you are just goint to use it as a show car you might be fine. If you give it WOT its a crap shoot at that HP and not a matter of if its a matter of when.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 02-10-2011, 08:08 AM   #6
JANNETTYRACING
JANNETTYRACING's Avatar
You have some Problems with your Wish List.
You will Void your Warranty.
600 RWHP puts you outside of any aftermarket warranty acceptance.
You will need the following to meet your goals.
2300 or larger Supercharger
L99 to LS3 Cam conversion Package with Blower cam
Long tube headers, High flow cats
Cold air intake kit.
MSD fuel pump voltage booster
10 PSI boost
Custom Tune to make it all work
I have complete turnkey packages to meet your goals.
We have a Customer in Baton Rouge LA running this set up with over 100 1/4 mile trips down the track with Lots of 10 second passes.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 02-10-2011, 08:13 AM   #7
JAB
C_H_E_V_Y
JAB's Avatar
10 PSI boost
Ted.
If you wouldent mind could you PM me with a price for one of those packages and I'm wanting to do it safest I can no matter the price, however anything over 15k I'd rather just have henessey do it and warranty the car again
Btw. It's a DD an I'd be Capitalizing on having the power not just a show car so I would definitely be upgradeing anything in the drivetrain that needs to be upgraded,
Heritage Grill
Chevy Bowtie Delete
Led Grill Lighting
Old 02-10-2011, 08:22 AM   #8
Jchaluja
Jchaluja's Avatar
Drives: ZL1 Camaro
if all goes well with your build, you'll need to do the trans eventually....
Jchaluja is offline   Reply With Quote
Old 02-10-2011, 08:46 AM   #9
JANNETTYRACING
PM sent with all the Details.
Ted.
Old 02-10-2011, 08:48 AM   #10
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
i wond er if ted's talking about me or someone else?
94guy is offline   Reply With Quote
Old 02-10-2011, 08:51 AM   #11
JANNETTYRACING
Hell Yeah, I think you hold the record for the Most 1/4 mile passes in a 2010 Camaro LOL
Ted.
Old 02-10-2011, 09:09 AM   #12
94guy
i kinda thought you were speaking about me. i can say go ahead and deal with Ted, he has gone over and beyond what i expected. i can't count how many datalogs he's looked at from my car One more thing get on his wagon and listen to what he says and do it. Good luck
Old 02-10-2011, 09:33 AM   #13
nyny69
Drives: 2010 IOM SS
94Guy,
What other mods do you have besides SC?
nyny69 is offline   Reply With Quote
Old 02-10-2011, 09:55 AM   #14
JANNETTYRACING
Originally Posted by nyny69 View Post
94Guy,
He has the Same List I posted with the addition of our Custom JRE ProTorque converter and drag radials.
Ted.
Forced Induction Supplements radz28 Forced Induction - V8 3 11-04-2010 11:13 AM
Forced induction help/advice! Chewy USA - California 11 06-09-2010 10:39 AM
Camaro 2010 Issues Tim's.2010.Camaro.SS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 57 06-04-2010 09:27 AM
Forced induction by other means Bell040 Forced Induction - V8 29 08-18-2009 07:00 PM
