04-18-2018, 05:28 PM | #1 |
Drives: 2016 2ss Join Date: Jun 2016
Upgrading the A.C. compressor
Since I put in the killer chiller the a.c. likes to blow warm at an idle when it's hot outside. Anyone have any ideas of an upgraded compressor or smaller pulley?
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in. |
04-18-2018, 07:13 PM | #2 |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
I would start by asking what your high and low side pressures are for a given ambient. If I understand this install correctly, you had to open up the AC system. Was it pumped down adequately and recharged by weight? And are the radiator fans working correctly? Bad A/C performance at idle is often a sign of bad airflow across the condenser or undercharge.
Assuming there are no glaring problems with how you put things back together, I would think new compressor or pulley is not the right approach to restoring good performance. You need to get heat out of the condenser. Maybe change the fan blades, install uprated fan motors, or install a bigger condenser in that case. Interesting problem. |
04-18-2018, 07:25 PM | #3 |
Pressures are good, I just checked them today. It was a little low so I added about a half a can.
04-18-2018, 07:34 PM | #4 |
Drives: 2001 Audi TT, 2016 Camaro Join Date: May 2016
PM Dave1SS. He has worked out all of the bugs on the Killer Chiller.
04-18-2018, 07:43 PM | #5 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2018
04-18-2018, 09:12 PM | #6 |
I got the pressure as close as possible to good. Ambient air temp 75, low side 42 high side 205.
04-18-2018, 09:13 PM | #7 |
How do you send a message to someone directly?
04-18-2018, 10:49 PM | #8 |
Top right corner. Your welcome statement.
04-19-2018, 11:44 AM | #9 |
Link to Daves1ss's thread:
http://www.camaro6.com/forums/showthread.php?t=503690 |
04-19-2018, 07:05 PM | #10 |
Drives: none Join Date: Nov 2012
I wasnt aware that the new refrigerant was even available outside of the pro environment yet... i.e. you cant buy it at autozone, oreilly, napa, etc...
So what did you add "1/2 a can of"? R134a? Because thats the wrong freon. |
04-19-2018, 07:18 PM | #11 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
Whoops double
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red Last edited by SnakeEyeSS; 04-19-2018 at 07:30 PM. |
04-19-2018, 07:26 PM | #12 | |
Well, actually you probably need a few other things. Like a vacuum down and a system flush, maybe, probably?, a new orifice tube if you used the wrong freon. Cars should have a sticker for refrigerant type under the hood. On the 6th inside the bottom side of the hood corner close to the steering wheel/left side of vehicle, right side when you are looking at it. (Varies by car model, my Honda and Mazda have it sround the radiator aroud or coolant expansion tank). They usually also have the capacity listed on that sticker, but some cars don't.
2023 Camaro ZL1 A10 Radiant Red Last edited by SnakeEyeSS; 04-19-2018 at 08:43 PM. |
04-19-2018, 07:54 PM | #13 |
Drives: 05 GTO / JETTA TDI Join Date: Jan 2012
A proper Chiller system will have no effect on vent temperatures. Jrs580 Email me if you want to know what is going on.
04-20-2018, 08:58 AM | #14 |
