12-05-2012, 03:58 PM | #1 |
Drives: 2010 Camaro SS\RS Join Date: Jun 2012
DIY needed?
Can someone point me to DIY for AEM boost and a/f gauge install?
Plz, thank you! Sent from my Xoom using Tapatalk 2 |
12-05-2012, 05:06 PM | #2 |
Drives: 2011 IOM 2SS/RS Join Date: Dec 2010
What part do you need help with? I don't think I have seen a DIY for gauges yet.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
12-05-2012, 05:49 PM | #3 | |
Sent from my Xoom using Tapatalk 2 Last edited by on3fastss; 12-05-2012 at 06:07 PM. |
12-05-2012, 05:50 PM | #4 |
Working on my 2nd one!
[SIGPIC][/SIGPIC]
12-05-2012, 06:01 PM | #5 |
My whipple has a port on the drivers side. It had a pipe plug in it from the factory. I had to buy a nipple for it at the hardware store. What blower do you have?
12-05-2012, 06:06 PM | #6 |
12-05-2012, 06:23 PM | #7 |
http://www.camaro5.com/forums/showthread.php?t=124493
Try this link. It has a diagram of where the booster fitting is on the Maggie. The brake booster line will only show vacuum, so don't put it there. Lol I tried it. Sent from my HTC One X using Tapatalk 2
12-05-2012, 07:04 PM | #8 | |
Edit: I'm an idiot ..... so the pressure sensor installs into the brass barb and the barb connects to the pressure cable? Sent from my Xoom using Tapatalk 2 |
12-05-2012, 07:22 PM | #9 |
I pretty sure this is correct, yes? Also a plastic tee is provided, it it optional to use or am I missing something? Sent from my Xoom using Tapatalk 2 |
12-05-2012, 07:32 PM | #10 |
That looks correct. You may not need the tee. If you have a BAP on your car the installer may have already used the boost port on the maggie for boost reference on the BAP. If that is the case, this is where you would use the tee fitting. Just make sure when you buy a nipple that you take the plug with you to make sure you get the correct threads. You wouldn't want to screw up the threads in the maggie. I also used a small bit of thread tape on mine. This is what the fitting you put in the s/c will look like.
12-05-2012, 07:43 PM | #11 |
Thanks bro... do you have air/fuel gauge aswell? If so, is the o2 sensor just a swap out or is there welding involved?
12-05-2012, 07:54 PM | #12 |
If you have removed your catalytic converters, you may have some bungs that have plugs in them. If so, you can just remove a plug and use one of them. If not you will probably need to have a muffler shop weld one in. Don't remove the forward O2 NB sensors, the computer needs them. Also, the WB will need to be installed pre-cat if you still have them.
I have Auto Meter WB and boost gauges. Sent from my HTC One X using Tapatalk 2
12-05-2012, 08:11 PM | #13 | |
Sent from my DROID RAZR using Tapatalk 2 |
12-05-2012, 08:18 PM | #14 |
Sounds like it. It shouldn't be to expensive. Just don't take it to Midas. Lol. I had a quote to get it done before I removed the cats, and it was under 100$.
Good luck. Sent from my HTC One X using Tapatalk 2
