Old 02-09-2017, 07:30 PM   #1
L99CAMA2011
L99CAMA2011's Avatar
Gates Blue racing accesory drive belt
Does anyone know who has these in stock? Gates K060827RB. Seems to be discontinued.
Old 02-09-2017, 10:12 PM   #2
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
I ordered mine from ebay about nine months ago.
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
tbss1 is offline   Reply With Quote
Old 02-09-2017, 11:40 PM   #3
L99CAMA2011
I got mine from Amazon 6 months ago. Amazon shows not available now. Rockauto I can't confirm.
Old 02-10-2017, 03:37 AM   #4
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
buying for a 25% underdrive?
JCunningham is offline   Reply With Quote
Old 02-10-2017, 06:20 AM   #5
L99CAMA2011
No just for the KATECH tensioner installed plus this belt performed better than the stock one for road course. Steering was firmer due to better operation of the pump.
Old 02-10-2017, 06:21 AM   #6
L99CAMA2011
Z28 serpentine belt
Does anyone know the dimensions of the Z28 serpentine belt parts # 12654814.
Old 02-10-2017, 07:39 AM   #7
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Gates had come out with a new line called RPM belts. I'm not sure but they may replace the blue ones.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 02-10-2017, 07:47 AM   #8
JCunningham
Drives: 2017 2SS M6
look what i found https://www.autohance.com/gates-raci...ro-v-belt.html
Old 02-10-2017, 01:28 PM   #9
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
You found another "out of stock" one!?!
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 02-10-2017, 03:05 PM   #10
JCunningham
Drives: 2017 2SS M6
it said in stock ready to ship when i found it. maybe L99 got the last one
Old 02-10-2017, 05:21 PM   #11
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
In stock....http://www.carpartsdiscount.com/auto...FcWIswodKXcE7Q
K060854RPM K06 13/16” x 85 7/8” - Black 6 85.33 2167 85.892 2182
Old 02-10-2017, 09:57 PM   #12
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Is this a SS part???
Orange Krush II
Old 02-10-2017, 11:12 PM   #13
L99CAMA2011
Stock SS. Mine however is going to be the K060827RPM from Carpartsdiscount. And yes this RPM one is the replacement. I like how it's firmer than the stock one on road course. On my Camaro it made the BMW M235 steering feel like soft a$$ crap.
Old 02-11-2017, 01:21 AM   #14
JCunningham
Drives: 2017 2SS M6
K060854 is the stock SS replacement size K060827 is the correct size for a 25% underdrive pulley.
