06-13-2010, 03:45 PM | #1 |
CCOTR Member
Drives: Victory Red 2010 2SS/RS A6 Join Date: Jun 2009
Pace Setter Headers...What do you think?
I am looking to purchase some long tubes for my L99 but dont have a ton of cash to spend. Has anyone purchased the Pace Setter long tubes and if so, what do you think of the quality, performance and sound?
Camaro Club Of The Rockies (CCOTR) Check us out on Facebook!
--------------------------- 2010 Camaro SS/RS Victory Red A6- Vararam Intake, Doug Thorley Tri Y LTs, Magnaflow X-pipe, Flowmaster Super 40's, VMS Tune, Razzi Ground Effects, Herritage Grill, RED headlight and fog light Halos, LED DRLs, Dash and extended Door ABL, engine, grill and rear defusser LED lighting ........ 12.59@112.21 (DA Corrected) |
06-13-2010, 03:54 PM | #2 | |
It just doesn't seem right to put a cheap set of Mild steel headers on a 35-40k car. 304 Stainless is the Minimum I would Recommend. Ted.
www.jannettyracing.com
06-13-2010, 04:00 PM | #3 |
CCOTR Member
Thanks Ted I certainly value your opinion. You have been great on this site. What headers would you recommend in the mid price range?
BTW....what is EGT?
06-13-2010, 04:13 PM | #4 | |
Exhaust Gas Temp. Mild steel starts to get overheated at 1050, and these cars see that temp daily. Stainless is good to 1600 this leave room so as not to over heat the metal. Good Read http://www.burnsstainless.com/stainlesssteel.aspx Ted.
06-13-2010, 07:59 PM | #5 |
Drives: Camaro Join Date: Apr 2009
Checkout the tsp headers. They're stainless and have a connection pipe option to run with stock h pipe. Later on you can upgrade to the tsp x pipe and muffler system! Checkout www.Texas-speed.com for info!
06-13-2010, 10:21 PM | #6 |
Drives: A wrench Join Date: Jan 2010
Pacesetters work just fine. I think the internet hypes up these $1500-1800 headers a little too much sometimes. I've installed 4 sets of Pacesetters on the 2010's so far with great results, and they fit just as good as the AR headers I install. Go for it if you're on a budget.
06-14-2010, 08:16 AM | #7 | |
Who wants Rusty Headers on a 35-40k car. We don't put Sneakers on with a Tux. It is not a question of If they will Crack but when, once they are cracked you throw away 500 bucks and buy a real set of Headers that will last as long as the car. If it was a 3K 10 year old car I could understand using Mild Steel. And you can get in to a real good set of Stainless Headers with cats for 1299.00, no need to spend 15-1800 Ted.
06-14-2010, 08:22 AM | #8 |
Pace Setters in general, thought about their exhaust systems too, but not that popular yet?
06-14-2010, 09:17 AM | #9 |
I agree that the stainless headers are a better option. We offer TSP headers with cat connection pipes for under $1000! That being said if your on a real tight budget the Pacesetter headers will get the job done. They sell for $600 with cats!!
We sell HUGE AMOUNTS of Pacesetters with very few failures. The ceramic coating will ultimately discolor a little bit, but keep in mind any coated header will discolor as it heats up. |
06-14-2010, 09:47 AM | #10 |
Drives: 2016 SS Convertible Join Date: Jun 2009
I was always wondering why Pacesetters were so inexpensive, now I know. Thanks Ted.
06-14-2010, 10:08 AM | #11 |
They Should Be 150.00
06-16-2010, 12:10 AM | #12 |
Drives: 2010 Camaro SS Join Date: May 2010
Hmmmm, In a far galaxy long ago there were HOOKER, STAHL, DOUGS and they were plain old steel headers....Cars back then made KILLER POWA but yes to a degree they did rust and fail over time...In the end the masses called out for a SS headers and they became aval at a reasonable price..
But those plain ole steel headers still work very well... We've made 635RW threw those so called CHEAP HEADERS Order them in painted and have a good 1600 Ceramic coating done to them instead of the 1200 Ceramic coating and they will stay just perfect for years to come... In the end u might have $750.00 total with 1600 coating and cats.. That can be a big savings for a guy on a budget... JMHO
SOLD
2010 Camaro 1SS/A6 12.59@111.31 Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned |
06-16-2010, 06:31 AM | #13 |
Drives: 2010 2SS CGM Camaro, 1988 6.6L IROC Join Date: Mar 2010
No disrespect to Ted because he does great work but regarding header material, I'd kind of have to agree with JS. People have ran mild steel headers on performance cars for years before stainless steel headers became more available.
When I first got my Third gen, I ran Hooker mild steel shorty headers painted with VHT with cats on my 350 and 383 TPI motor and they never cracked. Friends that ran the same setup didn't experience cracking either. I'm not saying they'll never crack, we just never experienced them. Eventually I went with SLP stainless shorties because they were the only ones available in 1-3/4". With my 406 I eventually went to the Dyno Don headers when they came out because not only were they 1-3/4" but also had 2-1/2" collectors and y-pipe vs SLP with 2-1/4" collectors and y-pipe. SLP stopped making thair stainless headers for Third Gens and Dyno Don's are the only large tube choice available. Alot of Camaros here in CA that I know of running them for the past few years with them catted with no issues of cracks because of heat. Maybe I could wrong and that there are people that have cracked Dyno Don's headers because of heat but I just never heard of anyone personally. In a perfect world, everyone should get stainless headers. But these days, a $500-$750 luxury is a more realistic goal versus $1200-$1600. Looks like the Pace Setters are available for $486 with their ceramic coat and 3 year warranty: http://www.maperformance.com/paceset...-70-2257m.html For someone looking for a little more performance and on a budget, that actually looks like a good deal. Just my 2 cent, take it for what it's worth... |
06-16-2010, 07:56 AM | #14 | |
I tend to recommend what I would install on my own cars. Being that I have been at this for 25 years Professionally and I have a crew of 9 people, there are a lot of vehicles that come through my shop, and I get to see first hand the long term results of using Mild Steel VS Stainless. We remove Lots and Lots of Rusted and or Cracked Headers, Albet we do live in the northeast where they salt the roads in the winter, even if you don't drive your car in the winter the Salt Lingers. Ted.
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com Last edited by JANNETTYRACING; 06-16-2010 at 02:12 PM. |
Similar Threads | ||||
2010 Camaro Pace Car Performs Flawlessly and with Ease!! | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 27 | 06-03-2010 10:52 PM |
The truth about Shorty Headers | JoshJ81 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 33 | 02-20-2010 01:44 AM |
2010 Camaro American Racing Headers FREE Shipping | MoranoRacing | V8 Bolt-Ons & Tunes | 2 | 02-10-2010 08:45 PM |
JBA releases exhausts, headers and midpipes. | Bewenched | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 09-16-2009 03:04 PM |
