08-07-2012, 10:48 PM | #1 |
Best way to relieve Crank Case pressue HELP!
i have a dual valve rx catch can and rx breather... and i am having trouble.. i have a whipple with a built 416.. i am leaking oil bad will know more tomorrow.. i am trying to see if my pvc system has something to do with this.. I have the fresh air tube removed and capped off both ends. I reved to about 5500 today when i saw a cloud of smoke. Took car home and now i have lots of oil leaking.
08-07-2012, 10:54 PM | #2 |
Drives: 700 rwhp 2010 SS Join Date: Sep 2010
drill a hole in the side of your block?
08-07-2012, 11:11 PM | #3 |
Perpetual Order
Drives: indeed Join Date: Jun 2012
where in texas are you?
08-08-2012, 07:42 AM | #4 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
Dang bro seems like you have bad luck, first the bearings now this.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
08-08-2012, 07:51 AM | #5 |
It might sound dumb but ck the oil filter same thing happened to me.... put a oil wrench on the filter...
08-08-2012, 08:58 AM | #6 |
Drives: 2010 CAMARO SS Join Date: Apr 2010
you might need to upgrade to the monster can if that is infact your problem
08-08-2012, 11:50 AM | #7 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Blake, I got a Monster can for my motor....its huge and the hoses are much bigger. I am not feeling too confident in my HKE motor lately. Its 2 1/2 months past his estimate and have no better estimate yet?
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
08-08-2012, 12:01 PM | #8 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Yes, anything over 10-12# boost and the Monster can is needed.
08-08-2012, 04:38 PM | #9 |
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS Join Date: Dec 2009
lol I guess this would eliminate the need for a larger catch can.
08-08-2012, 05:55 PM | #10 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
I had an oil leak after the Whipple install. Had trouble finding it. Two dealers told me it was the rear main. I don't think it was. I replaced the rear main, rear cover and gasket, oil pan gasket, and oil cooler seals. One of those fixed my problem. I believe it was the oil pan gasket.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
08-08-2012, 06:01 PM | #11 |
Drives: 08' F250 Diesel & 10' Camaro 2SS Join Date: Nov 2010
So I need to get a monster can...already? I am bumping 11.5-12psi
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets |
08-08-2012, 06:09 PM | #12 | |
08-08-2012, 06:16 PM | #13 |
Catch cans do not help relieve crank pressure, they help catch oil in the line. By design, they can only ever possibly be a restriction. Your best bet is to increase the size (and thus flow) of your vent lines and fittings all around.
08-08-2012, 06:17 PM | #14 |
problem fixed... took caps out fresh tube line back on with fresh tube line and a regular breather without the checkvalve... NO MORE LEAKS!!!
