09-30-2012, 11:26 PM | #1 |
Drives: 2011 Camaro 1LT IOM Join Date: Jun 2012
Adding air to tires .. Need recommendation
Seems I have troubles adding air to the camaro tires with my air compressor. Haven't ever had much troubles with any other cars. Wondered what air filler attachment everyone is using that likes it enough to recommend it. See many lock on and am leaning that direction as currently I just have the simple air attachment and it seems to either let more air out or doesn't get proper connection to inflate.
MRT2.0 with Helmholtz Pipes, Cold Air Inductions CAI, 4-Pack Gauges, Flat Black Stripes, Added Spare Tire Kit, Elite Catch Can, Chrome 20" Wheels, HUD, ABL Doors, GM Dovetail, Matte Black Gills, Rear Fascia Blackout
09-30-2012, 11:38 PM | #2 |
Drives: G8 Join Date: Feb 2012
Go to nearest DMV and turn in your license.
09-30-2012, 11:39 PM | #3 |
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
I use an air chuck similar to this and have no problems. You might just need to buy a new one. Most of the ones you buy like this are made in China. They are cheap and do not last forever. Any place that sells compressors will sell these air chucks.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
09-30-2012, 11:55 PM | #4 |
Drives: 2016 Mazda6, 2011 Mustang 5.0 Join Date: Mar 2010
Valve stems are generally all the same. If you aren't having problems with other cars, you shouldn't be with this one.
Have you ever had a flat tire, and used one of those sealant kits? I've seen that make a mess with the connector on an air compressor before.
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive." . 2022 1SS 1LE (Coming Soon) |
09-30-2012, 11:59 PM | #5 |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
What's the PSI read out on your compressor? Maybe there's an issue either with your compressor or attachment. If for whatever reason your compressor's pressure isn't greater than your tire's pressure 30lbs +, it won't do any good.
10-01-2012, 12:10 AM | #6 |
PSI on the compressor is 110. Probably time to buy a new chuck. One I have is the one they included with the compressor so likely the cheap china junk. Have had the compressor for about 8 years now.
