Old 02-12-2011, 03:20 PM   #1
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Need another place to get switched 12+ for Gauges
I bought an add a circuit but if I cant use it for f17 or f18 in driver side fuse box inside because it is only for 10 amp fuse and I cant figure out how to do it. If someone could let me know where else I can get power from?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 02-12-2011, 06:29 PM   #2
Luvpilot
Luvpilot's Avatar
Drives: GM
You could tap into the same one running your maggie coolant pump.
Pass-through just above the battery cable at the firewall.
I'm running a boost guage, an AFR guage and a radar detector off F17.
No problems.
Luvpilot is offline   Reply With Quote
Old 02-12-2011, 06:31 PM   #3
jsharp
jsharp's Avatar
How did you connect it to f17 though?
Old 02-12-2011, 09:05 PM   #4
GJG
GJG's Avatar
Drives: 2SS
replace the f17 20 amp with a 10 amp.....figure out which side is the down stream side of the fuse.....tap in on that side of the fuse....
Sleep well America.....my MARINE has your back......
GJG is offline   Reply With Quote
Old 02-12-2011, 09:59 PM   #5
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
Here is a gauge install how-to by Autometer...this may give you some ideas:
http://www.facebook.com/album.php?ai...d=282128680586
Kilo-9 is offline   Reply With Quote
Old 02-13-2011, 12:18 AM   #6
GJG
GJG's Avatar
Drives: 2SS
fuse tap
Old 02-13-2011, 07:02 AM   #7
EsteSS
EsteSS's Avatar
Drives: 2010 SS
Originally Posted by GJG View Post
fuse tap
That's incredible. I had no Idea that even existed. Maybe I should get out more.
EsteSS is offline   Reply With Quote
Old 02-13-2011, 08:28 AM   #8
jsharp
jsharp's Avatar
where you you get that fuse tap at?
Old 02-13-2011, 10:17 AM   #9
GJG
GJG's Avatar
Drives: 2SS
i just learned about them myself....1 came with my Maggie....i usually just push the wire in with the fuse on the down current side.....
i would think any auto parts store would have them or some variant.....
July Motor Trend, Camaro 3rd place to Mustang & Challenger OldJedi 5th Gen Camaro SS LS LT General Discussions 123 04-28-2010 06:13 PM
Local tire place messed up my paint, need advice philipdistefano 5th Gen Camaro SS LS LT General Discussions 35 04-21-2010 07:12 AM
L99 all over the place! 2SSARMY Dragstrip and Launch Techniques Discussion 24 04-20-2010 10:51 PM
Wheres a good place in North NJ to get a Maggie installed stealth camaro USA - NY / NJ / PA 13 04-15-2010 06:24 AM
Looking for a place to go hunting ZZcamaro Off-topic Discussions 11 10-07-2009 11:53 AM
