Old 06-26-2013, 07:43 PM   #43
MS7
MS7's Avatar
Drives: 2011 camaro LS3 supercharger
Originally Posted by blufin View Post
3.8 on the front is the biggest one they make, if I'm not mistaken. There may be a 4.0.
If not, you will need to get rid of the OD pulley on the rear and put a 3.6 on the front for around 8lbs boost.
i like the wine of cog drive. i hope 4.will works?
SLP TVS 2300,LS9 cam,ZL1 fuel bump, ADM FPCM,850ID,LT headers,CAI intake K&N, X pipe with stock exhaust Eibach 1inch suspension,Mantic Clutch 700HP, 91fule .8psi METH AEM, no timing up 557 RWHP
ZL1 black wheels,ZL1 front bumper, ground effects,
MS7 is offline   Reply With Quote
Old 06-26-2013, 07:54 PM   #44
MS7
MS7's Avatar
Originally Posted by Nitroman28 View Post
Why do you need to be at 8?
i was 6 psi with no issue. now i'm facing problems when upgrade it to 10 -11 so i decided to be around 8 psi. for safe side
Old 06-26-2013, 08:02 PM   #45
blufin
blufin's Avatar
Drives: Fire Engine
You can get a 1:1 rear cog drive. Get that and you can keep the whine and get the proper boost you're looking for.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 06-30-2013, 11:25 PM   #46
Zspoiler
Zspoiler
Drives: 1979 Z-28 RS Camaro
Forced induction
My 1979 Z-28 RS Camaro with an 364 cubic inch small block engine that been built from the bottom up to be supercharged . (Bowtie block forged stroker crank shaft, Milodon Road Race oil pan,MorosoWindage tray ,For. with a hydralic cam and Dart II iron heads( 2:02/1:60 valves.etc) and a Weiand 142 Mini-blower made 12 lbs of boost on pump gas. But now I have updated it with a set ported and polished Eldelbrock Performer RPM Aluminum with Manley 2:05 Intake/1:60 Stainless valves. Weiand 144 cubic inch mini-blower..040 Speed Pro Turbo /Blower pistons. Crane Hi-6 TR ignition box. I`m starting off firing on race gas then eventually see how low I can run a Race/super mixture. And put it on a chassis dyno.It should interesting.
Zspoiler is offline   Reply With Quote
Old 07-05-2013, 11:19 AM   #47
MS7
MS7's Avatar
i found it on ebay ..he will make it for me 3.7 or 3.9 or 4.0
Old 07-08-2013, 12:10 AM   #48
Jessika
Drives: Anything Blown
Jason, I know someone who's looking for a OD cog and has a 1:1. he's on the grrrr8 forum. Would you want to swap? I'll direct Daniel here if you do.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Jessika is offline   Reply With Quote
Old 07-08-2013, 10:42 AM   #49
daniel9357
Drives: slow
That would be me if your interested in that. Thanks jessika
daniel9357 is offline   Reply With Quote
Old 07-08-2013, 11:07 AM   #50
Jessika
You're welcome!
