Old 09-01-2014, 07:41 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
102mm throttle body
So anyone have one that noticed a difference?
I'm getting a procharger so I'm just wondering if its pointless to even get.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 09-01-2014, 09:38 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
It would only help if you have the 102 FAST IM to go with it. Your stock IM TB opening is still just 92mm. Even with the matching IM, I don't think they've shown enough HP gain to justify the $1500+ cost of the setup. The roots type SC's seem to show nice gains though. It does help that they don't have to fork out the $900+ for the IM though.
Bottom line, it's probably not worth the cost. Get a Bo White ported/modified TB and call it a day.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-01-2014, 11:35 PM   #3
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
im pretty sure the 102 wont fit the stock intake. you have to get a Fast 102 intake
JCunningham is offline   Reply With Quote
