11-16-2021, 06:27 PM | #1 |
Drives: Camaro Z28 Join Date: Jan 2017
► APEX | Rally Green ZL1 1LE on 18" VS-5RS Wheels
Rally Green ZL1 1LE | Featuring APEX 18” VS-5RS Sprint™ Line Wheels This ZL1 1LE left the showroom ready to tear up the track, but the factory wheels are heavy and not as robust as many drivers prefer. Now it’s ready to roll with a set of our new VS-5RS wheels. As part of our forged Sprint™ line, these are built to be extremely light while still offering a meaningful strength increase over our flow formed wheels. Engineered for drivers looking to shed as much weight as possible to improve lap times. Check out that deep concavity and side milling on the spokes! Brake Clearance was also prioritized with all of our Sprint™ Line designs and all new motorsports blanks allowed us to engineer 18" wheels that clear the massive factory ZL1 1LE brakes. Wheel & Tire Specs
Front: APEX VS-5RS 18x11 ET7 Wheels in Satin Black 315/30-18 BFGoodrich Rival S Rear: APEX VS-5RS 18x12 ET41 Wheels in Satin Black 335/30-18 BFGoodrich Rival S Images Learn More / Commercial Thread Last edited by Apex Wheels; 11-19-2021 at 11:06 AM. |
11-16-2021, 09:25 PM | #2 |
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE Join Date: May 2012
Looks incredible! Offset fills the wheel wells as it should. Nicely done.
Sent from my SM-T377T using Tapatalk
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery, Hooker Headers Blackheart exhaust,Powerbrake InstaGram & Twitter: @jlouie62 FB: hangtimeracing Last edited by jksynergy; 11-17-2021 at 07:52 AM. |
11-16-2021, 09:48 PM | #3 |
KaBoom1701
I approve
Mods:
11-17-2021, 07:32 AM | #4 |
Drives: 2014 camaro ss 1LE Join Date: Apr 2020
will this combo fit on a 5th gen? same offset? i dont see a 18X12X41 on the apex webpage only an 18X11X41and also dont see a 18X11Xet7 for the fronts listed.
2014 SS 1LE summit white
RWHP 1032 Modifications are as follows: Engine, forged and stroked 416 CI, Procharger F1A-94 with upgraded race intercooler and big red blow off valve, HP Tuner, AEM Wideband with Gauge, TSP Supercharger Camshaft 224/240 .615/.615 112 +3, Brian Tooley Dual Valve Springs, Brian Tooley Chromoly Pushrods and ported heads. Fore innovations twin 450 pumps on E-85 Brian Tooley Titanium Retainers, GM 3 Bolt Conversion, New GM Oil Pump, Injector Dynamics ID 1700 Injectors, Kooks 1 7/8" Long Tube Headers , Last edited by KevinHoward8509; 11-17-2021 at 07:46 AM. |
11-17-2021, 08:18 AM | #5 |
Wow that's crazy awesome looking!! I would love to have a 12 inch wide wheel fit on the rear of my 5th gen and not "poke" out like my 11.5 inch wide +30 offset Feradda's do with the 335/30/20 MPSS in my sig pic. Plus I'm lowered 1.5 and have no rubbing issues, but it would be nice to "tuck em in" more. Nice setup..
11-17-2021, 04:26 PM | #6 | |
That said, they will not fit under the 5th gen with factory fenders as they will sit out a touch. The front more so than the rear. Negative camber helps limit the poke, nor will they rub in most cases. |
11-17-2021, 04:34 PM | #7 | |
11-18-2021, 08:20 AM | #8 |
Thanks sir for the reply. Much appreciated. Do you have anything 20x12 for the rear? Asking because I have fairly new 335/30/20's out back. Also looking to keep the front at 20x10. Thanks.
11-18-2021, 01:42 PM | #9 |
Drives: 1997 Camaro SS Join Date: Jan 2010
Looks great, nice job Apex!
11-19-2021, 11:09 AM | #10 |
We don't have 20" Camaro fitments planned out just quite yet as honestly we haven't seen/felt much demand, however we do hope to come out with a few sizes next year likely ranging from 20x10 through 20x12".
11-19-2021, 01:17 PM | #11 |
Right on, thanks. Just asking because I'm not too sure how good a 19" wheel will look on my 5th gen. I appreciate your feedback.
11-19-2021, 01:41 PM | #12 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Just look to the 5th Gen Z28 when it comes to 19’s.
Orange Krush II
11-19-2021, 02:22 PM | #13 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
So this is not a mistake!
I applaud !!!!
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
11-19-2021, 04:23 PM | #14 |
Thanks, I will do that. I never paid much attention to the Z28's, thought they ran 20's as well.
