10-04-2010, 09:14 AM | #1 |
Drives: 2010 SW 2SS/RS 6M Join Date: Apr 2010
warped rotors-twice!
I've had to get my rotors turned- shaved (whatever u call it) twice in 7K miles on my 2ss. Has anyone else had this issue? I'm not driving through puddles. I'm not spraying water on my rotors when they're hot. I'm not riding the breaks. The service department didn't have any advice except to keep bringing it in since it's under warranty. |
10-04-2010, 09:17 AM | #2 |
SoCal C5 Family Member
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M Join Date: Jul 2009
Tell them to give you new ones the next time! Sounds like it is a rotor issue...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers; |
10-04-2010, 09:18 AM | #3 |
Drives: 2010 Camaro SS Join Date: Oct 2008
Wow....
There must be a problem..... |
10-04-2010, 09:20 AM | #4 |
Okie doke
Stop Standing on the breaks j/k
I'd ask for new rotors .. Crowley
10-04-2010, 09:23 AM | #5 |
Indie Zombie Film King
Is this an Automatic or stick? Keep in mind that an Automatic doesn't have the donwforce when it shifts through the gears as you slow down like a Manual will have and if you're a late braker.... you can warp rotors quickly.
Most people don't give themselves enough room to brake and then have to press harder in order to stop... you may not think you're doing but you are. Remember because of the size and weight of this vehicle you need to give yourself 160ft to go from 60-0 without issue... anything less than that in distance will cause you to heat up the rotors which in turn causes warping. If you own a stick use the gears to aid in slowing the car down. I see a lot of stick owners braking without gearing down and then only gearing down once they are at a stop.
I am also an INDIE FILMMAKER |
10-04-2010, 09:26 AM | #6 |
Drives: 2SS LS3 Join Date: May 2010
By grinding rotors (even once) you INCREASE the chance of future warping because the thinner rotors can't take the heat.
Get new rotors soon. I hope you can get GM to pay for it.
2010 CGM 2SS LS3, born: 4/10 |
10-04-2010, 09:33 AM | #7 |
I had this problem on my '06 Civic. After having the front rotors turned twice under warranty the dealer put on new rotors and pads. Problem stopped and I have 40k on this set (civic very light so pads should last 50k +).
2013 Camaro ZL1, Crystal Red, Auto, Exposed Carbon Fiber, Navigation.
10-04-2010, 09:34 AM | #8 |
What are the last 5 numbers of your vin# there were some problems with the early manufactured and numbered Camaros with brembo brakes.
2010 2SS/RS, Black/Black, LS-3, delivered 6/19/09
10-04-2010, 09:39 AM | #9 | |
TRI-COUNTY CAMAROS
Drives: 2SS/RS Oct 2009 Join Date: Oct 2009
Did the same with the early Nissan Armada's - rotors kept warping, Nissan gave me a fat check, then i turned it in end of lease
GET-TORQ custom CAM 223/243 LSA113, Full LS3 conversion, 3200 stall Multi-Disk TC from Circle-D, B&M Supercooler to cool that tranny down....1 7/8" Kooks Headers and High flowCats. MACH XL Catbacks. Eibach springs, R2C Performance CAI, powdercoated calipers, Footwell lighting in tune with dome lights, tints, ABL Lighting, ACS T3 ports and ACS Eagle T3 triple LED lighting kit. Heritage grill, Hex vents, ZL1 rockers, ZL1 Diffuser, Quad tips...the list keeps getting longer - whats next?? |
10-04-2010, 09:40 AM | #10 |
Drives: 2020 ZL1 Join Date: May 2010
Aside from the idea that rotors are a wear item, I'd ask the dealer to replace them with new rotors. If they are warped and they turn them, they are likely to warp again as soon as you start using the brakes. The OEM rotors don't have a lot of material to begin with, so if you take away some of it, it's going to heat up even faster and warp (again).
Other things to look at if this is happening on the same car is the hub surface may not be square, the back of the wheel may not be square, or the person who swapped the rotor put the wheels back on with a powerful impact gun and put too much torque on a lug. These are all things that can cause rotors to warp other than heat.
2020 ZL1
10-04-2010, 09:55 AM | #11 |
Drives: Love the one you're with Join Date: Sep 2009
Take the E-brake off before you drive.
And make them give you new rotors. Turned rotors don't last very long ,and if they were already turned once then their're done. You should turn rotors more than once in most cases. |
10-04-2010, 10:08 AM | #12 | |
last 5 of vin is 81381 |
10-04-2010, 10:09 AM | #13 | |
If you were in maryland that would be instant Lemon Law.... brakes or steering are automatic Lemon law items.
10-04-2010, 10:19 AM | #14 |
Drives: EXT Join Date: Nov 2008
GM had bad rotors on their cars for years but the SS rotors are the 14"ers. Might be a bad lot.
The above advice is sound. Get new ones. Good luck. |
Similar Threads | ||||
R1 Concepts Premium Rotors and Pads - limited time member discount/ groupbuy! | r1concepts | Suspension / Chassis / Brakes | 650 | 07-26-2016 08:22 PM |
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 49 | 11-13-2010 03:57 PM |
Stoptech power front and rear rotors for V8 or V6 | ImportImage | Suspension / Chassis / Brakes | 43 | 11-02-2010 10:00 AM |
Warping brake rotors | Angrybird 12 | Suspension / Brakes / Chassis | 13 | 12-18-2009 02:45 PM |
