Old 01-23-2013, 04:44 PM   #1
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
Which Melling to go with???
Will be doing a cam swap next month and looking to see which Melling oil pump to go with? I have had two good shops tell me opposites. One told me to go with the High Volume (10296) and another to go with the High Pressure (10295). Had a third shop tell me that they are pretty much the same thing. What have you cammed guys been going with?
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 01-23-2013, 04:48 PM   #2
Synner
Drives: cars
Use the high volume and it will come with a spring to do stock volume. Never been a fan of high pressure.
Old 01-23-2013, 04:50 PM   #3
mikeSS
mikeSS's Avatar
Drives: 2015 c7
Volume
Old 01-23-2013, 04:58 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
10296!!
And don't look back
Old 01-23-2013, 05:01 PM   #5
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
There is no reason to run high volume or pressure on a stock engine.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 01-23-2013, 05:01 PM   #6
Synner
Drives: cars
Originally Posted by litle88 View Post
And don't look back
But I like to heckle the guy I passed...
Old 01-23-2013, 05:07 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
What's wrong with a 10296?
Please explain.
Old 01-23-2013, 05:19 PM   #8
realcanuk
realcanuk's Avatar
I am not an expert but just went through this with the guy building my short block, who is one. (Bryan at LME). He is sending me a Melling pump with the engine which is checked over and ported, but runs stock pressure and volume. More volume isn't needed except for high rpm engines and should be used with a larger oil pan. Its rare but apparently there is a risk of running the pan low of oil. High pressure is not needed with stock bearing clearances and can damage seals. This is what I was told and it makes sense to me, so I'm going with it.
Old 01-23-2013, 05:41 PM   #9
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
10296 is what is recommended as the replacement pump been running mine on a stroker stock truck pan 25000 miles no problem
Fast6.3 is offline   Reply With Quote
Old 01-23-2013, 05:48 PM   #10
SC2150
Only use the high volumne in our builds. Volumne.
Pressure cost HP.
Old 01-23-2013, 07:43 PM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
The only way your gonna run the pan dry is if you don't have enough oil with this pump or your driving upside down.
I've done many 10296's and have yet to have a problem. Volume yes, pressure no.
Old 01-23-2013, 09:09 PM   #12
ITGuy11
Burning up tires
Drives: 2023 ZL1 Vert
10296 with the stock pressure spring installed that is included with it.
ITGuy11 is offline   Reply With Quote
Old 01-24-2013, 06:01 AM   #13
briancb1
briancb1's Avatar
Drives: C6 Z06
Is yours broken? Did it wear out?
Unless you're running higher than the factory operating RPM range, or you built a motor that has looser bearing tolerances... why change it?
They all have the same style reliefe piston so there is no fix if it gets hung up there...
Just because people sell them, doesn't mean you necessarly need it. I don't buy the "its insurance" pitch. Insurance against what? Never heard of 1 LS engine going down from oiling issues with a perfectly fine OE oil pump.... and you never will either.
From the 315hp LS1 to the 436hp LS3, they are practically identicle.
briancb1 is offline   Reply With Quote
Old 01-24-2013, 07:41 AM   #14
TXM62SS
TXM62SS's Avatar
Thanks for all the responses guys! Much appreciated!
3.91 1LE Gears, MGW
Tuned by Pat G
