Old 05-04-2013, 02:53 PM   #1
Threlkeld's SS
Threlkeld's SS's Avatar
Drives: 2010 camaro ss
Who's cammed with their stock oil pump?
Ok I've seen several heated debates about the melling vs stock pump, but now I want to who has actually cammed their car and kept the stock oil pump and timing chain? And if so how is it holding up? And the cam I'm looking at is the LR night fury and my car is a m6. Thanks
Threlkeld's SS is offline   Reply With Quote
Old 05-04-2013, 02:55 PM   #2
DieselMD @ Futral
DieselMD @ Futral's Avatar
Drives: G8
Have done many with stock pump and chain. No problems here.
DieselMD @ Futral is offline   Reply With Quote
Old 05-04-2013, 03:30 PM   #3
429
x2
429 is offline   Reply With Quote
Old 05-04-2013, 03:49 PM   #4
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
Very few untouched Ls3/L99 oil pumps fail, then you see quite a few fail on here after a cam swap. Everyone then says you should have replaced the POS factory oil pump, when in reality the installer failed more than likely. My .02 cents
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
kaler is offline   Reply With Quote
Old 05-04-2013, 03:53 PM   #5
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
My stocker (LS3) pump failed a year after the cam. I went with the GM high volume pump on the replacement.
gnturboray is offline   Reply With Quote
Old 05-04-2013, 04:00 PM   #6
Falundir
Falundir's Avatar
Drives: 2017 1SS 1LE - Hyper Blue, P85DL
2012 stock pump and 15k miles no issues.
Falundir is offline   Reply With Quote
Old 05-04-2013, 04:34 PM   #7
trw427ss
trw427ss's Avatar
Drives: 2013 2SS/RS L99
I have done to many to count with stock oil pumps and chains and had no problems and the only reason i have changed any is for high mileage! I will be doing my own soon and will be using my stock L99 oil pump!
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss is offline   Reply With Quote
Old 05-04-2013, 05:02 PM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Could the post-cam install failures be due to crap getting into the oil during the cam installs?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-04-2013, 05:13 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
No I doubt it Psj.
Old 05-04-2013, 05:58 PM   #10
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
I still have the stock pump, but went with the C5R timing chain.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 05-04-2013, 06:26 PM   #11
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
Swapped cam with 800 miles, now at 23,000 with stock chain and pump. Shift @ over 6,600 rpm at the track.
Irnwkrkev is offline   Reply With Quote
Old 05-04-2013, 07:10 PM   #12
Birm
Birm's Avatar
Drives: Florida Speed & Power
I upgraded timing chain, pump stayed stock. 18k miles cammed, 5k cammed and SC same pump.
Birm is offline   Reply With Quote
Old 05-04-2013, 07:39 PM   #13
NinoSS
Drives: 2SS/RS CGM LS3
About 6K since swap with OEM pump, still ok... I wanted to do it but was told not to worry about it...
Current - 2018 NGM 1LE (LT4 conversion coming soon)
SOLD 2010 LS3 / Vengeance stage I cam / CAI intake w/ADM race scoop / Dynatech LT's / Eaton Posi LPE-JRE 3.91's / L99 Corsa / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 05-04-2013, 07:41 PM   #14
Threlkeld's SS
Do you have to take the pump off to install the chain?
