Old 10-22-2013, 06:44 PM   #1
steven2680
Drives: ss beast
got my cam
What's up guys I got my from lethal racing but when I open it up I read the card and it say ls1 94& up now iam thinking my camaro is a ls3 now was it was a mistake or that's how it come any one had this problem be for thanks
steven2680 is offline   Reply With Quote
Old 10-23-2013, 11:26 AM   #2
Matt@510
Drives: c6 vette cam & full bolt-ons
you sure the card didnt say 97 and newer. ls1 didnt debut till 1997. most cam manufactors just list them as fitting ls1 still. they will work in the entire LS family line up with the correct cam sprocket of course.
Matt@510 is offline   Reply With Quote
Old 10-23-2013, 11:27 AM   #3
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Mine said same thing, LS1 1997 and up. No worries brother. Work in the whole LS engine line
Old 10-23-2013, 04:51 PM   #4
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Only problem you'll possibly have is a 3-bolt or 1-bolt cam sprocket. Unless you got the 3-bolt adaptor, then you're groovy.
The LS3s in the SS have a 1-bolt, and the earlier engines have a 3-bolt. Common conversion either way.
shibbs is offline   Reply With Quote
Old 10-23-2013, 07:09 PM   #5
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Lethal's cams are 3 bolt, and if you buy their kit, come with the correct sprocket
Old 10-23-2013, 07:33 PM   #6
steven2680
Drives: ss beast
I took care of already ane I am good the cam is fine for my ls3 and I have to buy the sprocket I didn't get the kit but thanks for your help and info
Old 10-24-2013, 12:39 PM   #7
briancb1
briancb1's Avatar
Drives: C6 Z06
If you dont have the 3-bolt gear yet... buy a Cloyes Hex-A-Just 3 bolt timing set and actually degree your cam when you install it. I love how obsessed everyone is throwing a bullet proof chain on a stock timing set and having no idea if its true or not...
briancb1 is offline   Reply With Quote
Old 10-24-2013, 12:53 PM   #8
BLACK10
BLACK10's Avatar
let us know if you need anything! yes all the cam cards say LS1 on them
Old 10-24-2013, 02:35 PM   #9
post some videos when you get it installed
Old 10-24-2013, 02:54 PM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
C5r chains by katech and fear no more.
Get rid of the chain tensioner and buy a 20 dollar Ls2/7 dampner because tensioners BREAK.
Melling pump 10295/6.
Old 10-25-2013, 10:54 AM   #11
steven2680
Drives: ss beast
In feb I be ordering more parts and maybe install it my self don't know yet since I read bad things happen when u do it wrong
Old 10-25-2013, 11:11 AM   #12
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
I notice you're beginning a trend of being a troll and a naysayer around the forums without having any substantial evidence to back up your banter. Please prove me wrong that you aren't indeed a troll.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 10-25-2013, 01:13 PM   #13
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
When I installed my comp cam and timing set, I was supplied with the wrong cam gear. Mine was a three bolt but it had a single reluctor and the LS3 requires a four reluctor. The car started but did not run right and I got a code right away. It would seem that although Comp knows about this they did not change any of their part numbers. When I talked to them on the phone, I was told that they did not even have the right gear in stock. I had to order one from Maryland Speed and change it out. Just throwing this out to those who might not know. Comp may have updated since then (I did my install in February of this year). I did all my own install work (would explain why I did not catch the problem during install) but all the materials were specked by a vendor on here for my drivetrain and driving specifications.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 10-25-2013, 05:00 PM   #14
steven2680
Drives: ss beast
Will do thanks
