06-08-2014, 12:28 PM | #1 |
Drives: 2013 Camaro 2SS Join Date: Feb 2014
LMR Punisher Package
Not sure if anyone here has dealt with LMR out of Houston or even has this package themselves. It seems to be a pretty good deal. I mean just doing heads, cam, headers, cold air and a catback would be pretty close to this price for the package. And you would get to keep your stock motor! Any thoughts, concerns, complaints please feel free to chime in! Link is below along with the components of the package!
http://www.latemodelracecraft.com/camaro-punisher.html Cold Air Induction System 1 7/8 stainless Steel Headers 3x3 X-pipe with high flow cats 02 Extensions NGK Spark Plugs MSD 8.5mm Spark Plug Wires LS2/7 Thermostat LS7 440CID. Shortblock: New GM LS7 block, Callies 6.125" H Beam rods w/ ARP 2000 7/16" bolts, Wiseco custom 4.135" forged pistons, NPR stainless chrome rings 1.2 1.2 3mm (for high heat applications), Clevite MS 2199 H main brgs, Clevite CB 663 H rod brgs, Dura Bond cam brgs and ARP main studs. Comp Cam Roll Master Double roller timing set w/ torington bearing & nitrided gears. Melling High Volum Oil Pump Comp OE lifters Water pump gaskets, Oil Pump inlet Tube, Front Cover, Cranshaft front seal, Oil pump inlet tube O-ring Rear main cover gasket and rear main seal Stage 3 LS7 Cylinder Heads with titainum intake valves and springs good to .670 lift Cometic Head Gaskets ARP Head Bolts Comp Hardened Pushrods LS Valve cover gasket set Oil Pan Gasket for 7.0L Assemble Longblock Underdrive Pulley Kit LS7 Crank Bolt RPS Twin Disk Clutch(CARBON) Slave Cylinder 55lb Injectors Customer Choice of catback Exhaust System Synthetic Motor Oil Oil Filter Coolant Shop Supplies Custom Dyno Tune |
06-08-2014, 12:39 PM | #2 | |
HT5 in the 626
Drives: 2014 Camaro 2SS/RS Join Date: Nov 2013
2014 L99 Camaro 2SS/RS ~ Flowmaster American Thunder Catback ~ Cold Air Inductions CAI ~ VMAX Ported TB ~ ARH Catted LTs ~ Tuned by Ted @ JRE A wise man once said, he who eats crackers in bed get crummy sleep. |
06-08-2014, 12:43 PM | #3 |
06-08-2014, 12:49 PM | #4 |
Treasure Coast Camaro 5
25k
06-08-2014, 12:50 PM | #5 |
Beat me to it. Think you are mistaking that the price shown is for adding Supercharging. Having a new engine built here and the parts cost for engine alone is much more than that. I am guessing for all that is included , installed and tuned is well north of 20k.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly |
06-08-2014, 12:51 PM | #6 |
lol Whats up UF Shouldn't you be out driving your car?
06-08-2014, 12:53 PM | #7 |
Waiting on yours! Yeah I should b.
06-08-2014, 12:54 PM | #8 | ||
Maybe I am expecting to much but I would think that $10K should get me at least over 500hp! |
06-08-2014, 12:58 PM | #9 |
Im a S/C owner but maybe ck out TT.
06-08-2014, 01:01 PM | #10 |
This is the Reaper Package for $9999. Claims 550hp for an L99 obviously at the wheels. Wouldn't that translate to close to 500hp at the wheels?
LMR Cold Air Induction System American Racing 1 7/8 Stainless Steel Headers/Connection Pipes with high flow cats 02 Extensions MSD Spark Plug Wires NGK Spark Plugs LS3 160* Thermostat LS3 Cam Comp Pushrods Underdrive Pulley Kit New GM L92 casting, 5 axis CNC machined, Fully assembled Intake Flow Rate 360 CFM Exhaust Flow Rate 245 CFM ARP Head Bolts GM Head Gaskets Front Cover Gasket Set Crank Bolt Mobil One Synthetic Oil Mobil One Oil Filter Custom REAPER Badging Install complete REAPER Package Custom Dyno Tune |
06-08-2014, 01:02 PM | #11 |
06-08-2014, 01:06 PM | #12 |
heres a dyno graph of a l99 I think single turbo
06-08-2014, 01:07 PM | #13 | |
Dlerch18 Keep in mind a lot of that is labor and LS7's are not cheap. Going a somewhat cheaper route LS3 Stroker+Progressive Funny Gas and parts only for it are somewhere just north of 12k and there are always numerous odds and ends that are needed and add extra expense. Like UF4LIFE102SS said TT Route may be your best bang for buck. Hagd can't escape to the office any longer. lol
06-08-2014, 01:11 PM | #14 | |
So I guess the L99 just doesn't make that much power with heads, cam and bolt ons! A TT or a S/C is the only way to go to get north of 500! Well my pipe dream has been crushed for a while!! LOL |
