Old 06-05-2019, 11:35 AM   #1
Fatal Ty
Drives: 1992 LS3 Typhoon
IAT2’s w/ Maggie
What is the best way to get actual IAT2 readings with a Maggie? The SC has a temp sensor on the PS in the blower assembly but the install directions note to tie that into the IAT1 from the MAF. I would really like to have data for both IAT1 and IAT2.
Thank you!
Fatal Ty is offline   Reply With Quote
Old 06-05-2019, 05:37 PM   #2
quinthawk
Drives: 2010 camaro ss, 2012 ZL1, 2021 LT1
The iat2 is only used on the zl1 and its ECU. If you have
a ecu from a ss (e38) it only has iat1.
quinthawk is offline   Reply With Quote
Old 06-05-2019, 06:34 PM   #3
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
It will read your Post Blower & intercooler IAT (what's actually going into the engine) after you make the connection and you can compare it to outside ambient temp for a reference.
swiftkart is offline   Reply With Quote
Old 06-05-2019, 08:41 PM   #4
Fatal Ty
I know the function of the IAT2, I would like to datalog it to see how efficient my IC system is working. It sounds like there may not be an easy way to add this sensor.
Old 06-06-2019, 05:28 PM   #5
swiftkart
swiftkart's Avatar
It gets the datalog signal from where they tell you to hook into with either SCT or HP through live wire or whatever logging system you use, been doing it for 7 years now, there's nothing hard about it
