06-23-2019, 04:23 PM | #1 |
Drives: white zl1 Join Date: Nov 2018
5th gen dsx pump
My car is a m6 5th gen Head/cam,2.35/9.1, dsx aux pump, id1300,dsx flex fuel kit, forged internals 10:5:1 cr! My question is when i i do a wot pull and my pump kicks on it jumps up to 70psi and by the time I’m at top of 4th my pressure is down to 50-52 psi, what could be causing this? I replaced the actual pump yesterday thinking it was weak maybe and cleaned the filter and it’s still doing same thing!
06-23-2019, 06:29 PM | #2 |
Drives: 2010 camaro ss, 2012 ZL1, 2021 LT1 Join Date: Oct 2009
Have the settings in the fpcm been changed?
Those need to be changed to allow higher pressure. I have the dsx parts,I have 85 psi. |
06-23-2019, 06:56 PM | #3 |
'It's an experiment'
FPCM and pressures in the tune can be adjusted..
I have the ZL1 fuel pump, BAP, and DSX kit — Dave adjusted my FPCM for me when I purchased the kit: -Don
747 RWHP 794 RWTQ
06-23-2019, 09:31 PM | #4 |
It looks like it has been, i did the conversion from kpa to psi it’s not as high as yours though
06-23-2019, 09:40 PM | #5 |
Yep, that should be updated. Dave Steck told me to raise mine. What I have is based on his and Mark’s (ABADZL1) recommendations... and the reprogrammed FPCM...
-Don
747 RWHP 794 RWTQ
07-11-2019, 10:59 AM | #6 |
Drives: 2014 ZL1 Join Date: Apr 2018
