02-17-2010, 01:40 AM | #1 |
Drives: 2010 2SS/RS L99 Join Date: Nov 2009
O2 sensor help
The Kooks LT tubes are on order! I'm planning on replacing all four O2 sensors rather than wrenching on the more than likely siezed units in the stock system. I'd rather buy four new ones than break one or two . Plus, this will make the header install and later reinstall of the stock system easier.
Can anyone provide the GM part numbers for the O2 sensors on a L99? GM parts prices tend to vary from dealer to dealer and I want to find a fair price. |
02-17-2010, 05:35 AM | #2 |
Drives: 2010 2SS/RS Join Date: Jan 2010
Mine is at the dealer right now getting 2 new sensors put in. I will get the numbers when I pick it up but its an LS3.
02-17-2010, 06:10 AM | #3 |
Pre Cat. 12617332 ACDelco # 213-4408 $134.82
Post Cat 12609457 ACDelco # 213-4229 $65.78 |
02-17-2010, 06:48 AM | #4 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
If you want to save some money, get some GM Heat Valve Lubricant. Part # 01052627. I've never used a better penetrating oil. Put a little on each the day before while the pipes are still warm. Put some on the next day while the pipes are warm. Let sit for a few hours, then take it for another drive to get the warm again, put a little more Heat Valve Lubricant on there, and start loosening while the pipes are still warm.
I've taken tons of them out that way and most of the time, especially if the car is fairly new, they will come right out. Trying them stone cold and no penetrating oil can often tear the threads right off. Also, use an 02 socket. Heat Valve Lube, an 02 socket, and doing it warm - I'll give you high odds at perfection. Stone cold with an open end wrench - often just tears up the threads. |
02-17-2010, 06:56 AM | #5 |
Drives: 2000 Silverado Join Date: Apr 2009
the rears came right outta mine, the fronts crossthreaded. i anti-siezed them all and they went in nice and tight.
save ur money........at least on the rears!
IOM 2SSRS LS3 R6P - VIN 7553 Delivered 5/22/2009 Kooks, Corsa and Roto-Fab - SOLD 9/2010
VR 2SSRS LS3 - Borla, SLP CAI |
02-17-2010, 09:36 AM | #6 |
02-17-2010, 09:39 AM | #7 |
I appreciate everyone's input. In my case the nearest GM dealer is over an hour away. It's best to have everything on hand before starting a job or I end paying wasting 1/2 day plus paying a premium price. Now to find an O2 socket.
02-18-2010, 02:34 PM | #8 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2009
02-18-2010, 04:04 PM | #9 |
Drives: 2010 AquaBlue 2SS/RS Join Date: Sep 2009
I don't think any O2 are cross threaded. Thread galling with stainless steal is the prob.Spray with Kano aerokroil before trying to loosen.Once it starts to come out spray more kroil in. Work senser in and out while spraying. They come right out.
02-18-2010, 11:29 PM | #10 |
02-19-2010, 08:44 AM | #11 |
Are the part numbers any different on the LS3?
02-19-2010, 09:32 AM | #12 |
Drives: 2010 Camaro SS/RS 6spd Join Date: Sep 2009
Just had headers installed on mine and they came out nice and easy, no stripping, no crossthreading. mechanic said they were no problem at all.
02-19-2010, 09:42 AM | #13 |
Drives: 2013 Camaro ZL1 Join Date: Apr 2009
It seems its a commong issue breaking 1 of them when you try to take them out. This happen to me too.
Devliered July 20, 2012
02-19-2010, 10:06 AM | #14 |
The newgmparts.com site does not show a different p/n for L99 or LS3.
It looks like the post cat O2 sensor has been around for a few years and it's also used on the Escalade, Silverado, etc. I ordered the sensors Tuesday morning and specified 2-day delivery. They showed up yesterday (Thursday) so they didn't waste any time shipping them. |
