03-16-2011, 01:51 AM | #1 |
...this is my addiction!
Drives: SOLD Join Date: Jul 2010
INSTALLED Light Wurkz Orion V2 Halo Rings
so finally this weekend i took the time to work on my headlight mod. The process with the headlights wasnt too bad but when it came time to remove my bumper... oh my goodness, it was hell cause i have big hands and arms and when i had to get that last screw on top inside the fender well.... jeezus christmas what an experience! anyways, here are a few photos a long the way...and i think it was well worth the trouble!
PIC1: after i finally pryed apart my headlight, make sure to remove any factory glue so u can seal it back up when done PIC2: remove the little hex screws from the inner frame PIC3: this is what i used to glue the halo on to the headlight frame PIC4: glued the halo on to the housing frame |
03-16-2011, 01:53 AM | #2 |
PIC5: this is how it looks when the glue sets
PIC6 and 7: i used one inverter per halo PIC8: this is where i decided to mount the halo inverter PIC9: installed the housing frame back to the headlight lense Last edited by 2FST2LIV2YNG2DY; 03-16-2011 at 02:29 AM. |
03-16-2011, 02:01 AM | #3 |
PIC10: during the process, i decided i wanted to paint the headlight housing flat black so my halos can stand out more and later i will install HID's in my fogs so i went for it!
I removed the part that i didnt want painted which was the turn signal reflector PIC11: i sanded the headlight reflector PIC12: applied primer to the headlight reflector PIC13: painted the headlight reflector flat black PIC14: drilled a small hole in the area with the red circle to get the wires out and reinstalled the turn signal reflector PIC15: took a break and ate some nice delicious home cooked rice with sauteed veggies and shrimp because the next part u want done right or your halo will be introduced to rain lol Last edited by 2FST2LIV2YNG2DY; 03-16-2011 at 02:34 AM. |
03-16-2011, 02:16 AM | #4 |
PIC16: got my silicone and rubber gloves ready cause its gonna get dirty
PIC17 and 18: i applied a little bit of glue in some areas to hold it tight so i can create a nice seal around the entire headlight. Dont be afraid to get your hands dirty and i recommend wearing rubber gloves so that u can move the silicone around to where u need it to be. make sure to apply enough glue so that it blocks any water from getting in, in other words, dont be stingy with the silicone. PIC19: finally after 2-3 hours trying to remove the fascia lol. seriously, trying to get to that top screw in the fender was a 8itch! that took about an hour lol sorry for the cloudy pic Last edited by 2FST2LIV2YNG2DY; 03-16-2011 at 02:36 AM. |
03-16-2011, 02:21 AM | #5 |
PIC20: this is how i wired mine, its personal preference. i wired them to the parking lights so when i turn the switch to enable the parking lights, my halos turn on.
The passenger side Halos brown (-) wire is connected to the black wire on the parking light harness and the halos white (+) wire is connected to the next wire over which is brown/white on the harness. The Driver side Halos brown (-) wire is connected to the black wire on the parking light harness and the halos white (+) wire is connected to the next wire over which is purple on the parking light harness. Heres an example... Last edited by 2FST2LIV2YNG2DY; 03-16-2011 at 02:42 AM. |
03-16-2011, 02:40 AM | #6 |
PIC21: installed the headlights and getting ready to fire em up...
PIC22: ...and voila!! I present to you Light Wurkz Umnitza OrionV2Rings So what do yall think? |
03-16-2011, 02:43 AM | #7 |
Drives: ( . )( . ) Join Date: Feb 2010
The halos look good, But i dont understand how are you gona drive at night and how are you not going to get a ticket??
But like i said, those Halos look really good |
03-16-2011, 02:48 AM | #8 | |
i did the same thing with my last car and had no issues, all i did was add HIDs to my fogs and i was good |
03-16-2011, 04:53 AM | #9 |
Drives: 2010 Camaro 2SS L99 SIM Join Date: Feb 2010
Are you going to use projectors since you blacked out your reflectors? How are HID's supposed to reflect from black paint?
03-16-2011, 09:40 AM | #10 |
Nooooooo. I'm converting my fogs to HID's not the headlights. I said it like 2 times.
Sent from my iPhone 4 using Tapatalk |
03-16-2011, 09:47 AM | #11 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
lol... so you are just going to leave the headlights not functioning? lol... This is different, that's all i can say really
03-16-2011, 10:03 AM | #12 | |
03-16-2011, 10:11 AM | #13 |
The Man in Black
Drives: 1969 Camaro 2010 Camaro 1SS Join Date: Apr 2009
I had thought of doing it this way and it has the look I wanted. looks great brother, we decided to just tint the healdlight assembly and add HIDs which worked for us the will be fine. Good luck and props for doing it your way
here is how we did ours http://www.camaro5.com/forums/showthread.php?t=129679 |
03-16-2011, 10:15 AM | #14 |
How about I get one of these if it makes u feel better lol
Similar Threads | ||||
HALO light bulb question | 2Muchmark | Cosmetics and Lighting Modification Discussions | 30 | 11-07-2013 07:00 AM |
Red led halo light | Cpiend4765 | Cosmetics and Lighting Modification Discussions | 81 | 04-17-2013 02:44 AM |
New information on the Halo light issues some have had | BlackIce1066 | 5th Gen Camaro SS LS LT General Discussions | 4 | 04-09-2011 03:55 PM |
FS: New White Halo Rings for RS/Non RS Headlights | coreyt | Exterior Parts & Accessories | 5 | 06-17-2010 12:05 AM |
Stock Chrome Tail Light Rings | GJG | Cosmetics and Lighting Modification Discussions | 3 | 06-07-2009 08:38 AM |
