09-23-2014, 12:47 PM | #1 |
Drives: 1968 Camaro RS Join Date: Sep 2014
Need help with head ID verification
I recently acquired a 1968 Camaro from a family member that was supposed to be an all original numbers matching '68 RS 327 2brl with a powerglide.
I'm looking at replacing the carb looked at the heads and noticed the camel humps which were on the 4brl 327 if I'm not mistaken. Here's the pic http://i.imgur.com/s9K0kbO.jpg Edit: here's the other side http://i.imgur.com/eZeKGTN.jpg Based on this website ( Head Guide ) it looks like they are e or f which they shouldn't be. If I am correct I have some number checking to do. Am I right? |
10-06-2014, 09:52 PM | #2 |
Pull off the valve covers and look for the cast numbers and date codes. Then, you will know...
1968 SS w/ 1966 427/425 Sequoia Green w/ Bumble Bee stripe. Always working on it... Drooling over the ZL1s. It will be my next car if I can manage to pull it off... |
10-07-2014, 11:24 AM | #3 |
Senior Camaro Fanatic
Drives: 2011 SS/RS manual - White Join Date: Aug 2010
Those are not camel humps. Camel humps are round. I believe those are original to the 2bbl engine. Let's call those two tick mark heads. They also had one-tick mark heads. Those heads you have are found on the "less than 275 hp" engines
Former '68 and '69 Z/28 Owner...........Now sporting around in a 2011 RS/SS with........Kooks LT's and cats, JRE tune, CAI, scoop, ZL1 Bumper conversion, custom ZL-1 grille, halo harness, Painted silver stripes, GM GFX, black painted lower edge of skirts and rear bumper. MGW shifter.....and now a 3.91 1LE diff
10-07-2014, 03:54 PM | #4 |
Drives: 1969 Z/28 + 2015 Z/28 Join Date: Aug 2009
f5journal is absolutely right.
10-09-2014, 12:56 PM | #5 |
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z Join Date: May 2009
+1 - f5journal is absolutely right.
Look at the leading front of the passenger side head. See if you can find the partial vin stamped on the pad. Here is a link you can use to find the pad location and decode the marking. http://www.camaros.org/drivetrain.shtml
- Buttons and Skulls -
miss my annimated signature. |
