07-23-2011, 07:58 PM | #1 |
CPO Pride
!!HELP!! Ithink this might be wrong
I installed a set of V6 Eiebach springs. Theses pictures are of the top of the strut towers as u can see I have a considerable gap. It doesn't move underload (driving) or make any noises but it just don't look right. Any one have any thoughts?
Navy Chief Petty Officers Pride IV 2017 Camaro ZL1 White on Black Past Cars: 2011 Imperial Blue 1LT, 2012 Imperial Blue 2SS, 2015 Black 2SS/1LE |
07-23-2011, 08:21 PM | #2 |
Drives: BLACK 2SS/RS Join Date: Sep 2009
Its normal....No worries....do a search and you will find dozens of other members who have asked the same question.
...and yes they do move. They cant/rock as you turn the steering wheel.
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint |
07-23-2011, 08:37 PM | #3 |
07-23-2011, 08:40 PM | #4 |
I just took a pic of mine to show you...crapy pic but you can see this is how they look.
CCW polished 505a's
07-23-2011, 09:16 PM | #5 | |
Drives: Camaro Justice Join Date: Jun 2007
The strut mounts articulate and require the space to do so. The next question is have you timed your bushes and realigned your car?
Your new coils and 5th gen will not perform as it should with your new lowering coils until the bushes are timed and the car aligned. |
07-23-2011, 09:33 PM | #6 |
CPO Pride
WOW. Thank for sanity check.... no I havent timed the bushing or had a wheel alighnment done yet. Monday is the visit date to the Dealer. I went to a local shop and they told me only the dealer could do it because the it was a 2011 and a CAMBER...? I
07-23-2011, 11:02 PM | #7 |
I guess thee dealer will take it from here. you may want to print out the alignment and timing post to take with you.
07-24-2011, 05:31 PM | #8 |
Hmmm, my shop sent it to Tire Discounters for alignment. Wonder if they
knew about this? |
07-24-2011, 06:10 PM | #9 | |
Drives: '69 SS Convertible Join Date: May 2009
You need to find an alignment shop that knows what to do or time the bushings yourself first and then go have it re-aligned. The guys are Tire Discounters probably only got your car within the acceptable range of alignment (green lights) as opposed to actually giving it an accurate alignment. An alignment that includes timing of your bushings is more than likely not going to be the standard $80 or so aligment. They'll need to add probably an hour or so on top of the alignment.
Build Journal |
07-24-2011, 09:57 PM | #10 | |
07-25-2011, 07:34 AM | #11 |
Thanks, I'll have to find a good alignment shop somewhere in SW Ohio.
07-25-2011, 03:31 PM | #12 | |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
To the Original poster - As mentioned before, this is absolutely normal. If you look at a car even on the showroom floor they do this. It's just a little more noticable after you've done work to the suspension.
Similar Threads | ||||
Kevin2323, you were wrong | DGthe3 | Camaro Price | Ordering | Tracking | Dealers Discussions | 65 | 10-14-2008 02:01 AM |
AW MAN I FORMATTED THE WRONG HARDDRIVE! | Dave McFly | Off-topic Discussions | 18 | 10-09-2008 04:07 PM |
Countdown clock is wrong | flaguy | 5th Gen Camaro SS LS LT General Discussions | 13 | 07-20-2008 05:48 PM |
