06-23-2014, 02:19 PM | #1 |
Drives: 2014 SS 1LE (RED HOT) Join Date: Apr 2014
That burning clutch smell?
So I have driven and tracked a lot of different cars with Manual transmissions. I know how to handle and take care of my clutch. However, I have on at least 3 ocasions since getting my car (2 weeks ago, still babying it) got that burning clutch smell. Once just pulling up my driveway! Is this normal for our cars?
RADEARTH
1SS 1LE RED HOT |
06-23-2014, 02:24 PM | #2 |
Drives: 2018 SS 1LE Hyper Blue Join Date: Mar 2011
When I really get on it I smell it too...I am not sure why though..mine has 6K on it and I just had it happen last week after a spirited take off..
06-23-2014, 02:47 PM | #3 |
Drives: 2014 Summit White Camaro SS 1LE Join Date: Nov 2013
I had the same issue with mine. I have over 10K miles on it now. What I learn after driving this car around quite a bit is; it doesn't like to be babied too much. If you try to reduce the driveline noises by being superbly gentle with it, it will just stink up the clutch. I drive in stop-and-go situations quite often, and when I take off in 1st, it is as if I am seriously going to get going. ( i hope that makes sense)
I usually skip 3rd gear for this reason, I might hit the teens(14-18mph) in first, move to second, make it to low 20s and go straight to 4th. 3rd gear is very tall and while I can use it, I have learned that I can be much smoother to the car and passengers by avoiding the whole thing. Hope this helps. Now drive, take chances, and have fun! (but seriously, be careful)
Drive Fast, Take Chances |
06-23-2014, 03:14 PM | #4 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
I had that smell for about 1000 miles and now, I don't remember the last time I smelt anything. It is hard for me not to keep my foot out of it every day. I run up the RPM's in first and second and your already in the 70 mph range, it is so easy to do. Love it!!!
06-23-2014, 04:50 PM | #5 |
Had the smell for about 1000 miles then went away. Hasn't been back.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
06-23-2014, 04:56 PM | #6 |
Drives: '13 1LE, '89 Caprice Join Date: Jul 2013
Twice with the hill start assist :/
06-23-2014, 05:49 PM | #7 |
Drives: 2014 1SS/1LE Join Date: Nov 2013
Stink was pretty bad for the first 700 miles, pretty much none after that
06-23-2014, 08:41 PM | #8 | |
Drives: GM Vehicles Join Date: Jun 2010
Apologies to hear about your burning clutch smell. Any displeasure is understandable and we're here to help should you decide to get an official diagnosis at a GM dealer. You're more than welcome to contact us privately anytime to discuss this in greater detail. William R. Chevrolet Customer Care |
06-23-2014, 09:18 PM | #9 |
Rally Yellow 2SS/RS/SR
Drives: Born 11/12 2012 Camaro 2SS RS 1LE Join Date: Sep 2012
15,000 miles on my 2013 1LE and it's common, depending on the circumstance.
06-23-2014, 10:47 PM | #10 |
Drives: 2014 AGM 2SS/RS 1LE Join Date: Aug 2013
I get it with the hill assist and when I'm a little slow letting out the clutch. Mines just over 500 miles now so I expect it will quit when I get some more mileage on it.
2014 2SS RS 1LE
06-24-2014, 12:06 AM | #11 |
Drives: 13' 1LE Join Date: Apr 2012
Hill assist sucks and sometimes the traction nannies will make your clutch smell too. Turn everything off when youre stepping on it.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
06-24-2014, 07:26 AM | #12 |
Drives: 2014 2SS 1LE Join Date: Sep 2013
Same with my car... Haven't smelled a thing since I broke 1000
14 2SS RS 1LE Recaro NPP Pat G cam and tune, Trick flow heads Long tube headers catless
06-24-2014, 07:56 AM | #13 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
I do not get any clutch smell.
06-24-2014, 11:16 AM | #14 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
Have not had the clutch smell either, even with the hill assist. Don't waist any time getting off the clutch, when you get moving come off that thing and kick it in the a**. They love to be driven with authority.
