Old 03-23-2016, 10:24 AM   #1
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
Stupid question
I have Flowmaster American thunder CB and high flow cats.
If I want to remove the cats I just go strait pipe from heAders to beginning of Flowmaster?
Looking for a little more flow and tiny power increase
TIA
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 03-23-2016, 11:17 AM   #2
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
1) Wrong section - try posting here: http://www.camaro5.com/forums/forumdisplay.php?f=11
2) Eliminating the high flow cats won't change the flow or add any power. Any changes will be minimal (1-2 hp), especially with your mods and current power level.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 03-23-2016, 12:57 PM   #3
TwentyTen2SSRS
Drives: 2010 2SS/RS
Okay that's what I thought as well.. Someone I chatted with last night from a sponsored vendor said differently..
Old 03-24-2016, 11:22 AM   #4
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Without the cats, the system is labeled as an "off road" system since the car won't likely pass emissions in most states or metro areas.
It's funny because the off road system are just straight pipes and are typically cheaper than the high-flow cats. Once you get into the more serious racing builds, then eliminating the cats have a bit more of a boost, but even then it's not much.
Old 03-24-2016, 05:23 PM   #5
TwentyTen2SSRS
Drives: 2010 2SS/RS
Thanks man! I'll keep the cats for now! Thanks again
