07-01-2014, 10:04 AM | #1 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
Maximum Allowable Front to Rear Diameter Difference?
What's the max difference in diameter between the front and rear tires before the ABS goes haywire?
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
07-02-2014, 08:40 PM | #2 |
1/2 inch. Might get away with a bit more, but it's a crap shoot.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
07-03-2014, 08:40 AM | #3 |
Drives: Race Car Join Date: Sep 2009
I've always been told the allowable difference is 6% front-to-rear. But that is a pretty drastic difference if you're talking strictly about outside diameter. I wonder if they're talking about circumference? But either way, as SSMickey mentioned, most people usually try to stick to a maximum of about a 1/2" difference in diameter, which seems to work pretty well.
07-08-2014, 05:54 PM | #4 |
Thanks guys. I'm looking at a set of the Hankook RS-3 Version 2 tires. Staggered 285/315 setup. Diameter difference is aforementioned 0.5" (actually it's 0.6").
http://www.tirerack.com/tires/tires.jsp?tireMake=Hankook&tireModel=Ventus+R-S3+%28Version+2%29
Thread Tools | |
