08-11-2012, 07:48 PM | #1 |
Drives: 2010 Camaro 2SS/RS White S/C Join Date: Aug 2010
ZL1 rear spoiler for a 2SS
Has anyone done a ZL1 rear spoiler for a direct replacement for the 2SS rear one? looking to purchase it and the ZL1 wheels!!!! If anyone has seen it or done it please let me know.
Thanks
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty |
08-11-2012, 09:45 PM | #2 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
Yes the spoiler and wheels
The spoiler will fit but you will need to do a few things. 1. Drill a new hole in the deck lid for the 3rd brake light wire 2. Either drill 2 new holes in your deck lid or cut off the 2 new posts on the spoiler (I did this). 3. Fill in the 3 remaining holes left by the OEM spoiler (the 3 holes are right under the 3rd brake light). Since you car is a 2010 if you remove your spoiler and you notice your paint is chipping you can use the TSB out by GM to have the trunk lid re-painted if you have a good relationship with your dealership they will fill in the holes as part of the re-paint. My dealership did this all costs covered. You will love the spoiler Sean
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
12-13-2012, 01:20 AM | #3 | |
YOU.ONLY.LIVE.ONCE
Drives: Camaro 2LT/RS 2013 Join Date: Aug 2012
Where did you get the zl1 spoiler?how much it cost plus the install?I saw one in CGM at the shop and I feel in love with the look. I also have GFX and ZL1 conversion. Raf |
12-13-2012, 07:35 AM | #4 |
#TeamBeckyD
Hi I purchased mine from Gary for $418 painted and shipped.
http://www.camaro5.com/forums/showthread.php?t=196947 I installed mine it was very easy I cut off the two posts on the ZL1 spoiler so it will use the factory holes in the deck lid, and drilled 1 hole for the wiring harness. Now the issue is once you install the spoiler you will have two holes under the 3rd brake light you have two options. I would plan on $300 to fill in the holes and re-paint the deck lid. Since you car is white I would opt for option # 1 a cheap solution and on white you would never know you had the plugs I have seen several on the forum go this route. 1. Email Maureen from Rodgers Chevrolet she sells plugs you can paint to cover the holes. or 2. Have your holes filled in and the deck lid and re-painted since my car is a 2010 I lucked out because I had the spoiler paint chip issues GM has a TSB out on this and it requires the deck lid to be repainted at no cost, the dealership filled the holes in for me.
#TeamBeckyD
01-31-2013, 06:36 AM | #5 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
How did you connect the 3rd brake light?
01-31-2013, 09:04 AM | #6 |
eeeeeeeeee
Drives: 2010 Black 2SS/RS LS3 Join Date: Sep 2009
What did you mean by the TSB from GM for the deck lid repaint?
01-31-2013, 09:40 AM | #7 |
#TeamBeckyD
http://www.gen5diy.com I purchase the wiring harness from Ofer.
GM Issues a TSB for the spoiler paint chip issue it calls for the spoiler and deck lid to be re-painted mine fell into this issue so the dealership re-painted the decklid, and filled in the holes at no cost. Sean
#TeamBeckyD
03-11-2013, 08:52 PM | #8 |
Romans10:9-13
Is there a how to or a instructional area on how to remove that side panel to access the wiring area?
I got my harness from him today, but have no clue on how to remove the panel.
03-12-2013, 06:33 AM | #9 |
lll
Drives: 2010 camaro ss L99 Join Date: Jan 2013
i bought mine painted off of ebay for 165 shipped and it was brand new. i used rubber grammets to plug the hole. it was great quality and i only had to drill one hole for the wire. also i didnt have to have any special wiring harness either
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ APPEARANCE COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING |
03-12-2013, 07:27 AM | #10 |
Romans10:9-13
You'll need some way to connect it. if you want the brake light to work, or does it come with a different style end?
03-12-2013, 07:46 AM | #11 |
lll
it is just a wire i have already wired mine in using an inline splice on the brake light.
PERFORMANCE
03-12-2013, 12:40 PM | #12 | |
#TeamBeckyD
Sean
#TeamBeckyD
08-11-2013, 12:52 PM | #13 |
So I just bought my 2013 2ss/rs and at the dealer I purchased the ZL1 spoiler... With all the mods, they have to fill the 3 extra holes with bondo and repaint. Sux. just bought a new car and already there is bondo in it :(
Question is that if I purchase the ZL1 wheels, are they a direct fit? Or am I going to have to do some more modifications and cut things up...? |
08-11-2013, 02:34 PM | #14 | |
Romans10:9-13
