Old 04-16-2015, 04:31 PM   #1
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
E85 questions...
I'm thinking about going E85 but what would I need to install? New injectors? Fuel pump? Fuel rail? And I'm doing a cam and getting my heads ported should I do this all at the same time and get a tune at the end? Also what are the pros beside of a power gain? And are there any cons?
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 04-16-2015, 05:50 PM   #2
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
....Power gain?? with E85? doubt it much...
kmarshall2121 is offline   Reply With Quote
Old 04-16-2015, 06:04 PM   #3
kmarshall2121
Reading up on it a bit, I see if you redo your injectors and tune it correctly, more power / torque is possible...
Old 04-16-2015, 06:15 PM   #4
krisprz2010camaross
Yah that's what I heard as well. But would know where I could get all the parts I need?
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 04-16-2015, 06:20 PM   #5
Homeless Man
Homeless Life Chose Me
Homeless Man's Avatar
Drives: LS3 (sold 4/21)
Isn't E85 cheaper but gives u less MPG?
Pity a man in familiar places, who yet feels like a stranger.
Homeless Man is offline   Reply With Quote
Old 04-16-2015, 06:53 PM   #6
krisprz2010camaross
Yup....
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 04-16-2015, 07:46 PM   #7
krisprz2010camaross
But my main question is if there is a kit available?
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 04-16-2015, 09:41 PM   #8
krisprz2010camaross
Bump.
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 04-16-2015, 10:38 PM   #9
krisprz2010camaross
Seriously?! No one knows a kit or at least knows the parts I can buy separately??
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 04-16-2015, 11:18 PM   #10
D3R3K
Sittin side ways
D3R3K's Avatar
Drives: 2010 2SS/RS IOM
Just do a flex fuel conversion. You'll need more fuel pump and injector to run it due to it using 30% more fuel. But you could run e85-or 93. Dave Steck has a write up about it.
850+hp club member
Procharger F1-A
D3R3K is offline   Reply With Quote
Old 04-16-2015, 11:22 PM   #11
krisprz2010camaross
Do you have a link? And where can I get the flex fuel kit?
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 04-17-2015, 03:50 AM   #12
jd10013
Drives: 2012 camaro
doesn't that maybe tell you something
jd10013 is offline   Reply With Quote
Old 04-17-2015, 06:48 AM   #13
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
E85 is more beneficial for force induction guys than N/A guys, I think you'll gain some power, but it's not going to be a significant amount.
It really helps the forced guys because of it's resistance to detonation and it's also alcohol so it cools down the combustion as well allowing them to make more power.
I think you'll find without being supercharged or turbo charged this isn't worth the time and effort.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 04-17-2015, 07:44 AM   #14
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
THIS.
I swear by the corn for FI though
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
