11-19-2012, 02:21 AM | #1 |
Drives: 2013 zl1 Join Date: Nov 2012
blower snout wear and noise
this snout has 600 miles on it. those are GROOVES worn in it from the spring loaded coupler i spoke about in the other thread.
just thought i would share.. |
11-19-2012, 05:40 AM | #2 |
I Carry!
Drives: 2013 CRT ZL1 Join Date: Jul 2011
Drive it till it breaks, then have GM replace under warranty.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540 From Oklahoma, Join us on Facebook https://www.facebook.com/groups/okcamaros/ |
11-19-2012, 08:38 AM | #3 |
Romanian Outlaw
Drives: 13 ZL1 , 14 Silverado Crew Cab Join Date: Apr 2010
That just makes me sick why they would not make a better part!!
[/SIGPIC]2013 Camaro ZL1 M6
11-19-2012, 12:14 PM | #4 |
Drives: 2013 ZL1 Join Date: Oct 2011
this issue puzzels me to no end. Is this an eaton or GM engineer that thinks this is acceptable?
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
11-19-2012, 12:55 PM | #5 |
What purpose does the spring loaded coupler serve as opposed to a solid?
11-19-2012, 01:13 PM | #6 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
It was explained in a past post that the wear in the displayed picture is normal by design and won't cause failure. I agree it isn't a good design, especially since the LS9 coupler fixes the problem, but neither GM or Eaton will do anything about it.
11-19-2012, 03:00 PM | #7 |
no, tec the shaft the spring rides on does nothing.. but my caddy had enough metal worn off to make me think what a shitty idea.. that metal CAN work its way back into the needle bearing that the supports the rotor shaft.. i guess they figure as long as it lasts 100,000 miles its ok..
11-19-2012, 03:13 PM | #8 |
I Carry!
Not bashing but trying to gain an understanding of this...these marks are indentions from a spring? How so if a spring is used for tension? These are obivious Metal to Metal wear on the snout? Is the spring rotating? Why are the forward marks deeper?
It seems that this is caused by "snapping out of the throttle and i guess any idle surges" per the other thread? Agree poor design, but more to this than we know.
11-19-2012, 05:28 PM | #9 | |
2015 SS 6M
The spring used in the Isolator Coupling is a torsion spring so resistance is applied by twisting the helix around the shaft. Since force is applied to the helix asymmetrically, meaning at the outermost coils, the shaft keeps the spring oriented so that force is applied to the spring in the direction of most resistance. As the helix constricts around the shaft, both the limited movement of the coils and the actual constriction of the helix cause friction between the coils and the shaft, leaving grooves in the softer metal. The spring is limited in how "constricted" the coils can get by both the number of coils and by the range of motion permitted by the Isolator housing. So there is also a limit to how much damage can be done to the shaft by the friction. The reason why the grooves are deeper at the end of the shaft is because that's where the variable forces are applied to the spring. That's where most of the work is done by the spring.
11-19-2012, 05:42 PM | #10 | |
11-19-2012, 06:17 PM | #11 | |
2015 SS 6M
I am definitely not a mechanical engineer so I suppose that would make me a good BS'r by default. However, I would put put my own money on my own words in this case. I trust me, you should too.
11-19-2012, 06:39 PM | #12 |
Ill take your word for it
11-19-2012, 07:31 PM | #13 |
Drives: Camaro's, always have, always will. Join Date: Oct 2010
...yeah, I'm ignorant on the intricacies of the LSA and wear issues but from a mechanics standpoint after observing the photo as presented by the OP this is a stupid mechanaical design showing so much wear after a miniscule amount of run time, WTF didn't they resolve this years ago....just sayin...
11-19-2012, 07:37 PM | #14 |
Raging Bull Reborn
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631 Join Date: Mar 2012
I am baffled too as to why GM isn't getting a permanent fix in place in front of the curve on this one. If there's not a permanent fix, when mine goes, I'll have it replaced under warranty; then put the new SC on the shelf, and drop in an aftermarket Whipple and be done with it.
Since I'm planning on a home brew COPO; that would probably make for the strongest build too; just an extra 6 to 7K for an AX175 or an AX245 Whipple (2.9 L or 4.0 L). One question, does the use of the Lingenfelter solid bushing 1. affect the warranty; & 2. how hard is it to take of the spring loaded part and replace it with the LPE part?
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631 Toy 2 '09 CGM Z06 3LZ My DD: '17 Ford Mustang GT Her DD: '14 F150 Ecoboost 3.5 |
