Old 09-08-2014, 09:28 PM   #1
JRC
Drives: 2014 2SS/RS
Header install question.
I have been looking for confirmation whether you can easily install LS3/99 headers with the car on jack stands? I don't have access to host. Any feedback would be great. Thanks.
JRC is offline   Reply With Quote
Old 09-08-2014, 10:06 PM   #2
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Yes, easily. Jacked the rear up as well, did headers and full exhaust. http://www.camaro5.com/forums/showthread.php?t=216262
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 09-08-2014, 10:13 PM   #3
rdrfronty
rdrfronty's Avatar
Drives: 2019 ZL1 1LE CRUSH
Did my LT headers this summer with the front on 10" ramps and the back tires sitting on about a 3" tall stack of wood plywood. This is on my 1LE. No issues at all. Wouldn't want to do it any lower than that though. So if your jack stands will raise the front of the body at least 10", you should be just fine.
2019 ZL1 1LE 6-Speed
Kong Ported Supercharger, Nick Williams 103mm Throttle Body, Roto-fab Big Gulp CAI, Kooks 2" LT Headers, AWE 3" Touring Exhaust, Cordes Expansion Tank, Mighty Mouse Catch Can, MS Tuning -- 661whp & 684ftlbs
rdrfronty is offline   Reply With Quote
Old 09-08-2014, 10:44 PM   #4
Avenging Orange
Avenging Orange's Avatar
Did mine on Rhino ramps...no problemo
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 09-09-2014, 12:07 AM   #5
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
took me 1.5hrs to do them on stands. I took the plugs out too. The oil dipstick tube is a pain to find the hole to put it back in.
JCunningham is offline   Reply With Quote
Old 09-09-2014, 07:25 AM   #6
JRC
Drives: 2014 2SS/RS
Thanks for the feedback. I will put in my order this week.
Old 09-09-2014, 08:52 AM   #7
Dfault
Dfault's Avatar
Drives: 2014 Camaro SS
I never have a had time finding the hole?
Dfault is offline   Reply With Quote
Old 09-09-2014, 09:53 AM   #8
Andy-AMSOIL
Andy-AMSOIL's Avatar
Drives: bicycle
Just a little more work.. no big deal though
Andy-AMSOIL is offline   Reply With Quote
Old 09-09-2014, 01:20 PM   #9
954camaro
954camaro's Avatar
Drives: Camaro SS/RS inferno red interior
Make sure your engine is a little warm because when I did mine one bolt stripped and was stuck in the block.
However, me being me I sat there for a hour turning the damn thread with vice grips with the littlest space possible.but it was worth it at the end
P.s based on what brand headers you will get will determine if it will be easy or not because the clearance will change a little with each header.
SoFlo Muscle Car Group
Miami/Broward
954camaro is offline   Reply With Quote
Old 09-09-2014, 02:44 PM   #10
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I did it on jack stand. Be sure to jack the car as high as you can. Be safe and put jackstand as many as you need. My 2" headers needed some hammer smoothing on the heat shield. Take your time and enjoy. Remove spark plug as precaution too.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 09-09-2014, 05:59 PM   #11
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I also did mine on jack stands. The O2s gave me a fit.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 09-09-2014, 09:21 PM   #12
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
Jack stands ftw
revived is offline   Reply With Quote
Old 09-10-2014, 10:47 AM   #13
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
+1
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 09-10-2014, 11:13 AM   #14
ytown87
ytown87's Avatar
Drives: C6 Corvette
jack stands here. like mentioned above the O2 censors were a beast to get out. GM stripped the threads and jammed them on making it almost impossible to work with. a second set of hands will help wonders as well
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
ytown87 is offline   Reply With Quote
