HeadlightArmor
Old 09-21-2017, 01:21 AM   #1
RamiJ
Drives: Camaro SS 14'
Brakes Changing
Hi Everyone,
I drive Camaro 2014 SS and last time I had sent the car to service center they sent me an estimation on break pads. I was wondering on when you should change break pads and does they last for only 30K KM, my car currently doing 65k KM which is 40K Miles. Last time I had changed the breaks was on 35K KM 21K Mile).
Is that normal?
I dont take my car into tracks, I just use it as a daily driver.
Cheers!
RamiJ is offline   Reply With Quote
Old 09-21-2017, 08:28 AM   #2
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: CGM w/Black stripes
It could vary by many things, but if they are stock pads, it seems they are wearing out a little sooner than others I am familiar with. But not by much, like around 25k-30k miles. You are in that gray area where they could be getting close to needing replacement and the service guy is just letting you know that you should be thinking about it soon, to change them out. Preventative maintenance is good.
Brake pads on these cars are super easy to change, so hopefully they are not charging a lot of time to replace them.
BMR Suspension, SLPTVS2300, GFORCE Driveshaft & HalfShafts, Kooks with cutouts and other fun things.
Old 09-23-2017, 11:25 AM   #3
RamiJ
Thanks buddy, well yes I think you are right cuz I checked with nearby shop and he was like those brakes would stay for another 10K at least.
Old 09-23-2017, 12:29 PM   #4
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
The OEM pads are excellent for a daily driver, and can last a long time. A quick look with the wheel off should give you a good idea how much further you can go before changing. There is a small metal piece on the face side of the pad that will give you an audible scraping sound if you wait too long to change them. Avoid this because you can score the rotor.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
breaks
