Old 07-05-2014, 05:27 PM   #1
C-redfly
C-redfly's Avatar
Drives: 2013 VR vert ZL1
20x10 20mm offset?
Can I use these sizes wheels on the front and rear?
Sent from my SM-N900P using Tapatalk
C-redfly is offline   Reply With Quote
Old 07-05-2014, 05:50 PM   #2
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
[QUOTE=C-redfly;7795484]Can I use these sizes wheels on the front and rear?
Sent from my SM-N900P using Tapatalk[/QUOTE
should be o.k., may stick out just a little past the fender edge
VR Baron is offline   Reply With Quote
Old 07-05-2014, 06:16 PM   #3
C-redfly
C-redfly's Avatar
Okay thanks I was pretty sure being the ZL1 runs 20x10 with 23mm offset.
Correct me if I'm wrong, 20mm would stick out 3mm more then the ZL1 front wheels.
Old 07-05-2014, 08:04 PM   #4
VR Baron
VR Baron's Avatar
Yes, 3mm more.
Old 07-05-2014, 08:51 PM   #5
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
3 millimeters is
0.118 inches
Should be ok unless you are lowered more than an inch. Roll your fender or you will cut the tires on bumps.
CHMSC is offline   Reply With Quote
Old 07-06-2014, 12:42 AM   #6
C-redfly
C-redfly's Avatar
I planned on doing a 1inch drop all around.
Old 07-06-2014, 03:18 AM   #7
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Don't run 20mm offset... I was sold a set and told they would fit... not only did it look like @$$ but rubbed on my fenders. That's with 275's.... 35mm offset is what you want.
Edit: Front 20mm sits perfect rear needs to be 35.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 07-06-2014, 03:21 AM   #8
MillerTime
MillerTime's Avatar
Originally Posted by CHMSC View Post
3 millimeters is
0.118 inches
+1 on the being lowered. Mine is lowered 1.5 in the back and as I stated above, rubbed like a mofo...
2G1FS1EWXD9163847
Old 07-06-2014, 10:42 AM   #9
VR Baron
VR Baron's Avatar
Yeah if lowering better research. As stated 1.5" will rub with just 275s. I had 315s with a 1.25" rear drop and o.k. But I had a 35 offset, you may have to go with the 35 or not lower it.
Old 07-06-2014, 02:05 PM   #10
MillerTime
MillerTime's Avatar
The 20mm offsets are for bmw's at least that's my understanding.
2G1FS1EWXD9163847
